Areo Brick
5 Attachment(s)
Well Started areo modding my little red Brick
Attachment 2931 As these should only produce minimal changes provided I dont increase the surface area of the vehicle or the total weight too much then it should be a net gain! First job Trash can wing mirrors Original Mirrors Attachment 2927 Attachment 2928 Have added fairings to these, might have an effect, will see over the next few tanks of fuel!! Attachment 2929 Attachment 2930 Redirect air flow from radiator Seems to warm engine up abit quicker!, will try a rad block over the next few weeks Hoping this will all add up to between 5 to 10% improvement in MPG :turtle: |
It doesn't seem to be a brick based on the picture. It looks very much like the US Pontiac TransPort minivan of 15 years ago.
Ray Mac |
Hello,
Can you post an overall picture, as well as some of the front, please? The overhead shot shows a "bulge" at about the back doors -- what's up with that? |
Odd shapes
As Soon as can get out will get side and other views
The bulge is where the "serena" variant ends and the "vannette" begins This vehicle is a merge between a MPV and a van, thus the bulge it is factory standard! |
2 Attachment(s)
Hi, I have a diesel Toyota Townace and am watching your thread with interest :)
Mine model Towny is the Noah with the small nose, rather than the flat fronted earlier models. Heres some picks I found online of someone elses. Mine has the double side doors and high roof, and the 2C diesel donkey and auto trans. I'm finding that a degree of drafting really helps with the aero brick :cool:Attachment 2975 Attachment 2976 |
Update pics
2 Attachment(s)
Hi all
here is front and side images Sort of brick shape to tight to go out and do A-B-A testing, will have to use data from next few fuel tanks, or until the gaffer tape give out and they fall off!! Front Attachment 2982 Drivers Side Attachment 2983 only problems seem to be there is no widely available data from the manufacturer for MPG figure and cd Cheers |
Hi,
Gaffer's tape never fails! :-) You could do with an upper grill block, I think. |
Rad block
That the next thing to go 4 neil
tough want to see what if any noticable difference the mirror modes make may do rad block at weekend if I can find some more cardboard!!! :turtle: |
Careful you don't overheat! Also, we distinguish between a rad block and a grille block. One helps with aerodynamics & warm-up times, the other really only helps with warm-up times.
After that, I'd be focusing on the underbody and the rear of the vehicle. The rear is where the biggest gains lie (though harder to fabricate stuff there). |
Confussion
Hi MetroMPG,
will be doing a Grille block, to aid with areo & heating, as you can see from photo front of Berther is a bit abrupt, so above bumper will be an areo Grille block, and below will be a straight rad block! As for the rear, need to fit new doors as someone arse ended me a few months back, and replace the rear bumper!! Thinking of ding underside and side skirts!!! also some work on air flow in the engine bay area as this has the potential for total enclosure giving quicler warm up times etc!!! :turtle: |
