Old 09-18-2008, 06:24 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
E10 Woes
Well in Florida nearly all pumps now a days have at least a 10% Ethanol blend in them. Yes its better for the enviroment, but it sucks for FE, as my car is struggling to reach 44mpg again.
Anyhow, I keep noticing that the gas station I go to often has slow pumps, so one day I walked in to ask why. The gas attendant told me it was because the fuel filters are clogged. He claims that the e-10 blend clogs the filters faster than regular gas and the owner does not want to pay for the additional maintenance.
So my question is; If this is happening at gas stations, what is E-10 doing to our cars? I know by volume we are consuming much less fuel, but in the time I have seen e-10 my mileage is begining to slide.
I am sure my car is due for a tune anyhow, but will this fuel shorten the lifespan of fuel filters?
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 09-18-2008, 09:07 PM   #2 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Back in the 70s, the product now called E10 was called gasohol. People came to loathe the stuff.
Your MPG is down because gasohol has a lower heating value than straight gasoline. Heat is what turns the wheels, Lower heating value means you need more fuel to go the same distance.
The alcohol in gasohol is hygroscopic. It readily combines with water (ask your bartender) and when it does it comes out of solution in the gasoline. It is so hygroscopic it will suck water vapor out of the air. When some of the vodka (water/denatured alcohol mix) hits the filter it clogs it.
Apparently, we are doomed to make the same blunders (in this case gasohol) every thirty years or so.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-18-2008, 09:16 PM   #3 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
The way I understand it; the reason Ethanol plugs Fuel filters is much like the reason that BioDiesel Clogs fuel filters; It's a great cleaner.
I never can get it; boaters complain the most about ethanol in fuel due to it absorbing water; but when they have water in their fuel they add Methanol . . . .
True less BTU's/ gallon . . .
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 09-18-2008, 09:29 PM   #4 (permalink)
Red
Red's Avatar
But on most modern gasoline engines, the fuel filter is in tank and its the first thing that your fuel sees. Fuel goes through the filter than the pump, lines, out the injectors. If its a great cleaner how does it then clog the filter? Gas tanks are made out of plastic so its not the tank degrading. Sure gasoline has junk in it, but not that much far as I know
Old 09-18-2008, 09:35 PM   #5 (permalink)
EV OR DIESEL
My experience with modern(ish) fuel systems is as follows
1) Tank yes crap accumulates here, not much, but some. Mostly Varnish, and oils which alcohol is good at cleaning out . . .
2) Pump Inlet screen I've never seen one plugged, I'm sure it happens . . . .
3) Fuel pump
4) Hose
5) Filter (mostly rearmount, or under the vehicle)
6) Tube to front
7) Fuel rail
8) Injectors tapped off fuel rail
***** Some cars such as new neons end here they use pwm controllers on the fuel pump to eliminate the FPR + Return hose**********
9) Fuel pressure Regulator
10) Return line to pump.
And the fuel keeps flowing. . . . Rund and Round like a record
Are you implying that absorbed water in the ethanol mucks up paper filters?
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 09-18-2008, 10:48 PM   #6 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
"Winter Gas" used to be 10% Ethanol, but I see the same sticker on pumps in the Summer now. I assume they won't be dumping-in any more this winter I can't keep track anymore...
Speaking of fuel filters, what's the replacement interval these days? I'm at ~80K since the last change...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 09-18-2008, 10:48 PM   #7 (permalink)
Yes I've heard all the horror stories but my experience with running not only E10 but E85 in various NON flex-fuel Fords is:
at concentrations of up to 50% ethanol, economy is basically unaffected
all these years I've never changed a single fuel filter or injector, or any other component for that matter
only issues I came across were hard starting in sub-zero weather when ethanol blend was over 50%, and poor WOT performance with 100% E85 (don't care though because I almost never go WOT).
Old 09-19-2008, 01:47 AM   #8 (permalink)
Red
Red's Avatar
RH77
Both the Insight and the Jeep claim life time. I'd say 100k for no other reason than a peace of mind
Old 09-19-2008, 07:11 AM   #9 (permalink)
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Hats off to BigDave, he hit the nail right on the head. Ethanol in gas causes more problems than it's worth. It says in many owner's manuals of small engine power tools that you should avoid gas with ethanol in it, as it causes the tool to be under-powered and has a tendency to stall. I just want to buy straight gasoline, but in the Socialist State of Massachusetts we have no choice, everything is E10 or greater. Just give me a choice, PLEASE!
And as an aside, Methanol is MORE hydroscopic than Ethanol and also mixes with ethanol. That is why it is used in 'dry-gas', because it goes out and finds more water and the crappy ethanol (it's not much better itself) and it allows the water to pass through the fuel filter (usually a synthetic filter with silicone in it to stop water from going into the pump, because water is bad for them), and eventually pass through the exhaust. Alcohol in gas is not good for fuel economy, it reduces the overall BTU value of the Gas, so you get less power from the same amount. BigDave said all I wanted to say, to you Bigdave.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 09-19-2008, 07:40 AM   #10 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
Has anyone done any real testing on the differences they have had with E10 vs. straight gas?
You know, I have been seeing things on Discovery for years about our shrinking farm land and our expanding population. It seems very shortsighted to me to start placing the demands of the fuel supply onto the food supply.
It does not seem to be the answer to me. People can get 25mpg, burn E85 and feel good about it. They can feel that they are "doing their part". I have to call BS!
Honda had an answer to this with the Insight. Suzuki had a lesser answer with the Swift/Metro. Toyota has small answer with the Prius.
GM had THE answer with the EV1! Of course the EV1 only worked for 90% of people. Well, boo-hoo.
We need to change WHAT we drive as much as HOW we drive. Trucks and SUVs are work vehicles, not commuter cars.
