Article: pickup mileage - manufacturers are ecomodding their trucks for better MPG
The Trucktrend web site has posted a fairly interesting/comprehensive article about what steps manufacturers are taking to squeeze more MPG from recent pickups in response to customer demand, the threat of rising fuel prices, and tightening fuel economy rules.
http://www.star-motoring.com/blog/ph...otorer64_2.jpg Let's get this out of the way first: the title - "Good to the Last Drop: Getting the Most Possible Mileage Out of a Pickup" - is ridiculous, of course. Obviously they're not getting the best possible mileage. Truck makers are notoriously conservative, and the spectre/excuse of "consumer acceptance" plus fear of halting/reducing the ever-increasing towing/payload specs keeps them from doing anything beyond incremental changes. But the article does cover a wide range of tweaks, and interestingly it quantifies many of them in terms of effect on MPG. Weight reduction:
Improved aero:
Nissan's engineer comes across as the most pessimistic of the lot: Quote:
Haha, I like the first comment:
I noticed that one too. Also, that Nissan engineer's attitude is disappointing.
Gee, I have a hard time recognizing what type of vehicle that is. |
Here is a thought. Don't buy a giant 3+ ton truck. Just imagine how much fuel you'll save.
Nope, nope, can't do that! :rolleyes:
Gigantic ladder frame underneath means there's an awful lot of turbulence. Did the engineers forget that the whole truck is a wetted surface?
And what about those GARGANTUAN wheel openings? That drives me crazy, there's enough height above the tire for me to be able to insert my entire head! In my brain, the winning model is to get the biggest bed you can in combination with the smallest engine. Drive gently, as if going faster cost more. ;) Settle for somewhat less sprightly performance when carrying heavy loads and towing. I know, common sense and all that. And yet, precious few people buy the big box stripper model. That's a shame. 'Cause the world needs more strippers. |
elhigh, you know why they design them with those huge wheel openings, right? Otherwise, in the commercials when they drop that huge load of bricks in the bed from 20 feet (just like you do so often in real life), the tires don't touch the wheel well. I mean, you don't want to get the impression that your suspension will bottom out when you exit the second floor of the parking garage the fast way.
I would have preferred a manual and higher gears, however manuals are virtually non-existant and I got a great deal on the truck I found. |
Something like the T100 with a 4 cylinder and a 6 speed. It would carry the regulation 4X8 sheet of plywood if memory serves me right.
regards Mech |
Taj Mahauler: We Drive Mahindra's Diesel Pik-Up - PickupTrucks.com News http://blogs.cars.com/.a/6a00d83451b...2d7e970b-800wi |
Lower axle ratios will help, but the rest of it is just nibbling around the edges of the problem.
As I put it here: Piddling-around efforts bring piddling results. You want big improvement, you gotta go to war. 1. Real aero improvements. Ask Phil Knox. 2. Diesel engines. Yeah I know the EPA hates them 3. Get rid of the dratted torque converter transmissions. Go with a manual or dual-clutch transmission. |
What do they do in Europe, where gas has consistently been >$6/gal? I bet the answer involves diesels, compact cars towing things Americans "need" a truck to tow, vans, and using the smallest truck necessary for the job.
In Germany, you can get a Mercedes-Benz Sprinter pickup: Mercedes-Benz Deutschland - Technische Daten - Maße & Gewichte If you select the 4 cylinder diesel with the six speed stick, you get 29mpg on the Euro combined cycle, and a 2200lb payload capacity. Go with a big V6 gasser, and you get an unimpressive 18mpg. |
I have always argued the v8 is not allowed to get out of its own way enough and put power down. I experimented with this growing up. the 300 hp v8 with non-grandma actions got 10mpg more. The whole think needs to be scrapped. starting with drivetrain. Not one idiot thought of the benz crank v8. the counterbalanced engine is a half butts attempt at one engine being a diesel and gasoline..the diesel wins with the crazy design. They never evolved to gas properly. Today with delayed injection, the sloppy lower half sucking up 40% of every revolution needs to be smartened for injection alone as an argument. Engineers are stuck, they are capitalized, they are owned. Game over.
I have owned trucks and maintained v8s for years. All goals were to gain power..it saved fuel every freakin time, all versions even the boggy smoggers of the 1970s. today is even more difficult because of injection. Injection is a SLOB. ALL VERSIONS..ok mr.piezo? |
