Artificial Feathers to Reduce Drag?
I just read this in New Scientist. Seems pretty interesting, though it would be a pain to make and align the number of 'feathers' required for the back of a car.
Here's the link: Fake feathers could take the drag out of flights - tech - 13 April 2009 - New Scientist Anyone want to try it? hehe |
I don't think this have much to do with the feathers themselves. By placing the feathers in the way they did, they effectively altered the shape of the cylinder, making it more like an oval, which obviously have a lower Cd.
Birds have feathers because you can't grow smooth plastic sheets
feathers
PBS Television had a program entitled "Raptor Force" and it got into modern aeronautical engineering's quest to adapt a bird's body-morphing abilities for fighter aircraft.In the show,they attached small closed-circuit television camera broadcast equipment to falcons and owls to get airborne with them.When "looking backwards" during flight,you could see how the feathers behaved during glides and stoops.One thought that grabs you,is that a feather is part of a closed-loop feedback system for the bird.Each feather is mounted in an articulating structure surrounded by nerve endings.During flight,if the bird's angle of attack causes detached flow,the bird can alter it's shape or orientation with respect to the surrounding air mass to regain attached flow.Herein lies the greatest benefit of the feather.It "signals" efficient flight and is constantly relaying real-time data to the flight control portion of the bird's brain.---------------------------- No doubt,bio-mimicry can aid airflow to an extent,but perhaps never to the degree of a living morphable structure.
maybe some day birds will be made of carbon fiber |
Any roughness will improve a cylinder, or a golf ball, so the example is spurious. However, there is a lot to be said for adaptive surfaces. Organic fliers seem fond of using attached vortices to extend their performance envelope. Car bodies don't usually have such radical changes in angle of attack. Feathers also have excellent structural advantages, being surfaced with velcro-edged strips that resist tearing, but can be repaired instantly.
Borrow a stereo microscope, and take a good look at the small-scale structure of a feather. Then try to figure out how to build something with the strength/weight ratio of a wing primary feather out of a smooth plastic sheet... |
than again one day maybe.... "feathers" in the broad sense of the word could be interesting to smooth out the underside of the car, especially things like inner wheel wells etc... |
On short notice I could not find an article that highlighted this, but scientists have already replicated this effect and already use it on airplanes.
The effect is not obvious because you miss it in the confusion of the wings. Mako sharks have a rough surface that has valleys and hills that traps a layer of water against the scales. The water-water drag is 10% less drag than that of smooth surfaces(fiberglass boat hull). They already manufacture the crap it comes in big adhesive sheets that are applied to airplanes along the wings and fuselage. Feathers aero properties do the same thing trapping a layer of fluid(air this time) against their body to decrease drag. As many have already said feathers also have the ability to manipulate on the fly to take advantage of air currents. Cars could do this but it would be extremely complex and require lots of processing power. Birds don't usually get the advantage of having other objects moving at the same speed around them unless they are travelling long range in a flock. Cars would be able to take advantage of vacuums created by cars in front of them by flattening out the front to provide a larger surface to attach to the vacuum or foil out when in the lead. So behind a semi you would look like |> and then otherwise you would look like this <>. |
Feathers, fur on otters and seals, etc. also act as compliant wall surfaces, helping to dampen the oscillation of turbulent flow at its source, thereby reducing drag. This per research by Denis Bushnell et al at NASA Langley in the 1980s, with whom I spoke briefly at the time.
Also, some homebuilt airplane guy in Alaska about that time tried an experiment where he says he put fur (coulda been polar bear fur, but I don't recall exactly) on his plane, and reported that it reduced the drag, presumably for the same reasons. He approached the Air Force with this idea, and they told him to take a hike. This per Sport Aviation article at the time. Perhaps this phenomenon stems from the same concept as the Sinha deturbulator tape, which is claimed to counteract turbulent flow as it begins. Comments? |
That technology works by trapping a layer of fluid against the surface "permanently." It doesn't flow at all. The barrier allows for a semi-compressable membrane that can assume the most hydro-aerodynamic shape possible within the micro-meter thickness. The drag between the fluid air and the trapped air creates a lower drag. It would be like engineering panels on a car that could manipulate slightly to take advantage of instantaneous low or high pressure zones and then return to normal as they dissipate. Infinitely more efficient than actually using a mechanical system because the sensors would disrupt flow and the equipment would be bulky and too slow. |
Google for "Sinha deturbulator tape." He's reportedly done work in conjunction with Mississippi State University, no slouch in the aero department. Doesn't answer emails, though. The soaring crowd was pretty stoked about this concept, and apparently did some comparative glide tests, and found the tape worthwhile due to significant gains in L/D.
Anyhow, I suspect there is more to it than maintaining zero flow at the skin surface, per shark skin. Denis Bushnell was ~27 years ago looking for a good shark to freeze and test in the NASA Langley wind tunnel, as part of his compliant wall surface study. The 3M riblet film used on America's Cup sailboats was based on the sharkskin concept, certainly good and an improvement, but perhaps not be the final word on optimum skin design. Feathers evolved over millions of years to do several things, including streamlining, but also as insulation, chill factor being what it is at altitude and speed. Perhaps we should have a closer look at the Arctic Tern, which flies pretty much non-stop from pole to pole. Surely, this is one of nature's finest works, from which we might learn. |
The airline industry already adopted a film of this nature as I also already mentioned. The designs are the same but the airline industry did it back in 2000.
The purported max on decreased drag was 10% though. Lately, I've had my fill of "phenomenon" events that offer answers without any decipherable science behind them. Particularly ones that have already been explained but are not useful in vehicles. It's not really about zero flow at the surface because my sheet metal doesn't flow at all. Its about a continuously, infinitely variable surface that can respond to oscillations in the fluid and either expand into low pressures and pull the surface(the trapped water which will provide a df of force on the sheet metal) or compress away from high pressures to avoid drag. Your sheet metal, FG, CF or whatever will just be pulled on creating a tiny force that increases drag instead of compressing or expanding(only microns) to "evade" that increased pressure. Unless its quantum physics or something of the magnitude of 50% of the universe we can explain most events if not in words and elegant equations then in extremely complicated mathematical formulae. A CVT takes advantage of the same idea. If your transmission is static you can't decide that the tractor trailer is providing a very friendly FE spot(yes its still FE friendly 2 seconds behind him) and gear appropriately for max efficiency at that speed. You are stuck. CVT slides its cone outward a little so your gearing gets you taller and taller until the engine is producing just enough power to maintain speed at the lowest possible rpm and you didn't have to leave the FE sweet spot behind the semi to get into that sweet spot rpm. The fluid surface does this. Low pressure sure I'll expand into it to create larger surface area towards the low pressure and pull with a tiny amount of force. High pressure I'll compress and cause less force to be imparted into the sheet. |
