EcoModder.com
-   Open ReVolt: open source DC motor controller (https://ecomodder.com/forum/open-revolt-open-source-dc-motor-controller.html)
-   -   ATmega168 Processor Speed ??? (https://ecomodder.com/forum/showthread.php/atmega168-processor-speed-13171.html)
sawickm 05-07-2010 09:11 AM
Looking at the Wiki’s current BOM I’ve noticed that it still references the “ATmega8” processor.
On this forum and on Paul’s website it shows the current use of a ATmega168 for the Cougar Controller. What is the actual ATmega168 part number currently being used ? Processor speed ??? ATmega168-20PU or 10PU ???
Also, for the new synchronous rectification controller what processor is being used a ATmega168, AT90PWM3B, or dsPIC ???
Anyone know the status of the new synchronous rectification controller ???
-Mark
MPaulHolmes 05-08-2010 11:20 AM
ATmega168-20PU (I think that means it can go up to 20 MHz)
SR controller uses dsPIC30F4011.
The status is, the board is done, but not fabbed. Here's the dilemma... I want to get Eagle, so ordering boards can be done much cheaper, but it's $1000. Ordering boards from the free software company is really expensive, and the other company that will let me order from them, needs a bunch of screen shots of the pcb to be able to write it in their own pcb editor I think. I just need to do that.
The point is, the board is just sitting there bored! hahaha.
I have a fully assembled control board from the first SR controller that won't work, because I used the wrong type of DC-DC converter for the high side drive. I've tested the VLA-15151 DC-DC as a high side power supply for the charger, and it works great.
