Audi a3 1998
I am thinking about ordering a mpguino as i don't have a trip computer.
All my efforts to visualize real time consumption were too much complicated for real life use... I connected a vag com cable to a computer, then sen't singal to a multimedia radio via a avermedia Vga to video converter, all this with the electrical adaptations due to voltage of different devices... Picasa Web Albums - cesardeluxe Now it is time to make it simpler I have many questions BUt lets begin with 2 can i get L/100km measure? Where is VSS and injection on my audi? Who knows maybe somebody can help THank you a lot, i admire all i have read from you! great web! |
I have found a pinout for the ecu
Bosch ME 7.5 ECU http://www.me-mo-tec.de/content/down...?file=2011.pdf i doubt if i should connect to it directly..i think i have to look for the wires located on the harness.. if i find it! according to that vcc is pin 2 and injection is 22 right? by the way don't iso audio connectors to radio systems have a vss wire? then i would need to get the injection cable only, where is injection plug in the motor? i should tap the one without 12v... |
The audi a3 has a vss wire to the radio system. That is what I know..
