Old 04-01-2012, 02:05 AM   #1 (permalink)
2004 Mazda 6 - '04 mazda 6 S
new member in a mazda 6
hello people I'm new to this interesting site I'm going to be doing most of my logs manually for awhile cause i don't have $140 to spare for a ScanGaugeII.
anyway I'm driving a 2004 Mazda 6 (S trim) without any mods yet. but i did just purchase a k&n typhoon intake to replace the OEM one that I managed to tear a hole in through silicone hose of.
anyway I'm good for recommendations for the next mod and i will try to get the money for a ScanGaugeII, but no promises.
Old 04-01-2012, 09:36 AM   #2 (permalink)
Welcome to the site.
I'd say forget the intake. Nobody has ever tested a cold air "performance" intake here and shown it has any benefits to mileage. It might give you a tiny bit more horsepower is all.
I suggest starting with the 100+ hypermiling tips list (up top) and the 65+ mods list. These are proven ways to increase your mileage.
Old 04-01-2012, 10:03 AM   #3 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Welcome !
Look over those lists above, then look at our wiki car mood page.
Mods at the top of any list:
Scan gauge ($150, check ebay) or ultra gauge (75$)
Grill block
Smoothe wheel covers
Is it a manual transmission? If so a kill switch can help you coast while using no gas at all.
Old 04-01-2012, 03:21 PM   #4 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Welcome! You don't have to go big money to get results here!
The BIGGEST mod you will ever make will be your mind in discipline in how YOU drive!
We like to call that adjusting the nut behind the wheel!
Plenty of info here. Just soak it all in!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 04-01-2012, 11:17 PM   #5 (permalink)
Rookie Ecomodder
zoomzoom - '06 Mazda 6i sport
Loose the trunk wing, wind deflector -if you have one, and unscrew the roof mount antenna for starters.
cold air, cold air intake, intake, mazda, mazda 6
