War_Wagon |
10-30-2013 09:30 PM |
A dealer ad in the "By Owner" section, that's always a good sign that the guy's not a kink ha ha. And I've always wanted a car that ran "smoth". The CVT Insights didn't have lean burn, so keep that in mind, and from the looks of that place, if you do go look at it, do yourself a favor and run a carproof or some other history check on it. And make sure the IMA light comes on on the dashboard when you first turn the key, it should do a self check along with all the other dash lights before start up. If it doesn't then there is something funky going on to cover up a dead IMA battery. Good luck.
