Auto Intermittent Deer Horn - How to?
I would like to out fit my car with an intermittently beeping horn that can be operated via a toggle switch. Ideally the horn should emit short (1/8-1/4 sec.??) beeps about once each second. I need an electric horn, a (HD) horn relay, wire, fuse & fuse holder toggle switch and ... An suggestions for a cheap, ready made actuator circuit? Intermittent wiper are too slow. Emergency flashers are 50% on 50% off and speed is dependent on load. |
Cherry Bomb. Loud pipes save lives ;)
You need a timer.... Like the one I used for turning a cheap digital camera into a time lapse camera :)
Quick and Easy Electronic Time Lapse http://www.instructables.com/files/d...MRN.MEDIUM.jpg If you can solder, the kit goes together in a few minutes (at least for me) - aquick google search, and I found a place selling the same timer I used Adjustable Interval Timer MK111 - VETCO.NET That's how I'd do it cheaply... |
http://i456.photobucket.com/albums/q...me/circuit.jpg
http://i456.photobucket.com/albums/q...aneme/Text.jpg If you understand all this than it will be simple to build and you wont find a cheaper way I dont think. You will need a transistor on your output to power your relay. |
Spec. for the kit is
