Automatic transmission - coasting damage?
I have a 2003 GMC Yukon XL 5.3 vortec.
Here in Britain petrol is pricey, so I run my yukon on LPG at less than half the price. I get about 18MPG(UK Gallon) but we can always do better :) However, there is a long hill on my drive to work which I can coast down. I was wondering does anyone know if it does damage if you still have the engine running but put the auto gearbox in neutral. I have done it a couple of times and instead of reading 3Litres/100Km, it reads 1Litre/100Km. Someone told me you shouldn't coast automatics, so until I find out more info I'm back to leaving it in drive. |
No, there is no damage done by coasting.
When I coast my automatic, it's when I intend to stop a ways ahead and engine braking is too much deceleration. I leave it in neutral until the light turns green, there seems to be a significant reduction in fuel consumption idling in neutral vs. idling in drive.
I've also pushed it back into drive while still coasting occasionally, and it doesn't seem to do anything bad, but I hesitate to do it regularly. |
the age old auto transmission coasting debate,
There are plenty of threads on this one but here is my understanding of auto transmission coasting. The general check people seem to do is to check if their car can be flat towed (towed by a truck with all 4 wheels on the ground compared to just the back 2 wheels). If the car can be flat towed then there is little risk in coasting in neutral since flat towing is basically coasting in neutral. People are generally concerned about a lubrication issue, with the transmission unpowered some people believe that the oil pump isn't pumping much or any oil in the transmission which will cause gradual damage to the transmission. As for my own experience, i have been neutral coasting for maybe 6 months now and i have had 0 issues, i pulse and glide (glide in neutral) then pop it back into gear after reving the engine to rev match. I also have recently installed override switches for the torque converter lock up and the gear selection solenoids. With the torque converter lock up control i have little worries about shifting back into gear when coasting because i just unlock the torque converter shift into drive (the slush box takes up the slack i believe without any stress or damage) the engine naturally matches RPM when i put the gas pedal down a bit then i lock up the torque converter and keep driving. Its only an issue when i forget to unlock the torque converter when i coast down to lights, i pop it back into gear and the car has stalled out once or twice. Regarding going back into drive while still moving at high speed, when i didn't have override control of my transmission i did have some issues if i was traveling at around 60 mph, if i went back into drive without rev matching well the transmission would shift down a gear and rev really high. |
Automatic transmission design can vary, and whether you can shift back into drive while in motion without incurring damage is questionable. One of the most expensive repairs imaginable on any vehicle is an A/T rebuild - so be careful. Saving a few $$ in fuel is not worth causing well over a thousand $$$ in repair. I'd suggest you consult with a transmission shop and ask them the question directly. They can give you good reasons why you shouldn't do it, if it can't be done without doing harm. |
I know mine can be "flat towed" but it involves stopping and holding 2wd hi and 4wd low for 10 seconds. Obviously this is something I cant do at 50-60mph.
Due to the large engine of the yukon it cruises at 50mph at about 1500rpm, idles at about 700, I'll take note today whether the rpm spikes when I go from neutral to drive at 50mph. I don't suppose anyone on here knows anything about the specific transmission this has? It was built in USA in 2003 and privately shipped to UK, but when I check gallery pictures on edmunds website it seems mine is identical to the 2004. It has the 285bhp 5.3 vortec. It can be hard to find out info here in the UK as GM didn't release the suburban/tahoe/yukon/yukon xl in the UK, although recently they started selling the escalade and H2. There's probaly less than 100 of them in the country and garages want to charge a premium for their know how. But I guess its the price I pay for having an American car in England, your cars are so much better than ours. |
Coasted it today, to observe any spike in RPM, there was none.
The only issues I know of are that some auto transmissions suffer the aforementioned lubrication problems if you coast with the engine off. With it on, there shouldn't be any problems.
-soD |
After searching for more data I found info on what American refer to as Dinghy towing, from an RV/motorhome.
It seems the 2003 yukon can be flat towed with xfer box in neutral, 2004 yukon is just towable as is. My dilemma is mine was built in 2003, but appears to be 2004 spec. If i can confirm it is the one listed on 2004 then I could even EOC |
Just to add, mine is canadian spec
The owners manual only says to leave the car in drive because you are more likely to cook your brakes without engine braking
All that means is, "Don't be stupid. If you are, it's not our fault since we told you not to."
I own an Infiniti Q45 2002. I bought it at 40k. I have coasted w/ engine on for the last 5 yrs. I have 219,000 miles and still have the origial transmission. I can shift in and uot of neutral while coasting at speed. I agree that each vehicle is different but I can speak for infiniti.
I found this site Free VIN Decoder - Vehicle Identification Number Report
You type in your VIN and it gives you a shed load of info on your specific model. Seems I have the 285bhp engine from 2003 so I can coast, but not EOC |
I've spent a couple of days coasting on my journey to work. The problem is I've been working nights and the weather has been rough. So coasting with headlights, 3 wipers, heater, heated seat, heated mirrors and radio on have taken their toll.
I went to start it the next day and it was almost flat, it just started, if it hadn't started any savings I made would have been wasted in lost pay for being late. So I'll probably leave the coasting for daytime dry days when I only have minimal electrics running. |
I tried it for a week. My gas milage increased, but I just keep getting stressed by obsessing over it. I also was anxious about damaging the trans.
I stopped doing it. The anxiety wasn't worth it. I drive an automatic chevy aveo. Not the best fuel efficient vehicle, but atleast its better than my last car. |
Ben if you were costing and then the next day you had a hard time starting the car then you need to get that problem fixed. You should not have a problem starting as the alternator will still charge the battery when coasting, check the grounds for the starter and to the battery if those are fine and clean it might be time to get a new battery.
FWIW -- the 2011 Chevy Cruze Owners Manual says the automatic transmission model can be dinghy-towed (flat-towed) in neutral at moderate highway speeds as long as the vehicle is started and driven once per day.
...that's the GM Hydro-Matic 6T40 (RPO code MH8) 6-speed automatic transmission, which is also used in Malibus and Buicks. |
