Automatics and Neutral?
I've read people arguing both sides of this coin so I wanted to know what everyone here thought or knew. Is it safe to transmission pretty quickly. I've also seen the same arguments for overdrive.
I ask because switching into neutral on the mountains is very very useful sometimes... |
I've done it for around 10k miles so far. I've read others have done it longer w/ no ill effects. That being said there will always be naysayers who whine about the possibility of working on their own car, so if you're in that camp, don't bother. Otoh, if you find the idea of a swap to a manual transmission if/when the auto fails appealing, git 'er done!
Owner's manual?
Some manufacturers warn against, some dont. On a Volvo v70 diesel, the revs go up to about 1300 rpm until you press the brake pedal enough for the brake light to switch on. Shifts smoothly to a suitable gear at any speed anyway.
I can not think of any way to damage the 'box if the engine is running. That way you must have normal oil pressure to lube the bearings? Disclaimer: I'm not a gearbox expert. |
Rule no. 1: the engine must run if the wheels are turning. Seriously. I don't know how many miles it takes to ruin an automatic, but the input shaft is integral to the lube getting around inside there while it's turning, so there's that.
Here's another thing: shifting into neutral in a rental Impala, I noticed my instant MPG would skyrocket, but usually not bury the gauge at its upper limit of 99. Coasting with my foot off the gas, but the tranny still in gear, the instant MPG would hit the upper limit and stay there until I got back on the gas. The reason: The ECU was completely shutting off the fuel to the engine. The tranny was dragging the engine along at or above the cruise control setspeed, no more fuel was needed, and the engine was doing above idle speed, so no fuel needed there, either. The fuel injectors simply stopped injecting. Your experience may vary, especially if you're driving a carbureted vehicle. This was my experience, and that was in a late-model large sedan that was, frankly, optimized to do its utmost with every gallon at cruising speed. For such a large car, 27.8mpg at 75mph is really very very good. |
Hot Rod discusses this in a tech question this month for sticks. I'll see if I can dig up the page number. Basically the same conclusion though. In a carburated car it makes sense but with EFI it actually uses more to idle than engine braking since the injectors are not squirting fuel.
What About MFI? I don't know about the neutral thing. My vehicle coasts about twice as far in gear than in neutral. Neutral doesn't get the slight pushing force of the tranny as is in gear, and my vehicle's electronic system shifts seamlessly into neutral at high coast speeds anyway, and goes into gear when it's supposed to be out of O/D because the rpm's aren't way high like in neutral would be.
If the engine speed under some amount, usually ~1500rpm when warm, the ECU will start injecting fuel and the auto will pretty much be idling in gear, even if your foot is off the gas pedal.
What exactly does throwing it in neutral do? shut off fuel and the drive train from moving? All I know is, I can coast way farther in gear than out of gear, and that it will be in neutral coast when I'm first coasting.
N disconnects the engine from part of the transmission, so instead of moving the whole engine/transmission, the wheels only move part of the trans. When you're coasting in gear the above some speed the engine is operating just about as inefficiently as possible.
In neutral, the tranny and engine are each turning at whatever speed they will - the tranny's speed is dictated by the rest of the drivetrain; the engine will hold the speed you determine via the accelerator pedal.
I don't fully understand all of Roflwaffle's above statement - if the engine is being dragged along by the tranny, and the engine is EFI, the injectors won't have anything to do. Little or no fuel will go through the system. If you're looking for a longer coast, though, well then you should shift to neutral. Then your EFI will turn up the wick a little bit to keep the engine turning over. This is as it should be. Carbureted engines don't coast in gear as well as EFI; the engine tries to become an air decompressor, pulling a vacuum against the back of the throttle plate. EFI doesn't do that. If you're driving an SUV or an offroader or a Jeep (which is both), you may have a pretty loose Torque Converter in your ride. A looser TC will amplify torque more when there is more slippage between engine and transmission, at the expense of more slippage at full speed. Most TCs have a lockup clutch to prevent that when cruising. Let off the gas, though, and a lot of the lockup clutches immediately release - your engine will drop right down to idle. It feels like neutral, but it really isn't. The TC probably has enough drag in it to pull the engine up off idle a little bit, so the EFI can back way off on the fuel it delivers. Then, as your speed drops to near zero, the TC drags from the other side, and the engine is generating enough power even at idle to continue propelling your car. Torque converters work great at transmitting power from the engine into the transmission. However, diode-like, they are nearly worthless at transmitting power from the transmission into the engine. That's why you can't roll-start an automatic-equipped car. NO manufacturer will equip a vehicle that shift out of and back into gear for itself. NONE. This would expose them to tremendous legal risk. Remember Audi in the late 80's, and all that BS with "unintended acceleration?" That was almost the end of Audi, at least in the States. |
I'm going from my owners manual. It says that it has some sort of thing that seamlessly shifts out of gear and into neutral while coasting, then seamlessly shifts back into gear when power is needed. I might be wrong though, so I'll check the manual again to make sure after I get off from school.
As for my thoughts on it, I say check the manual first to see if the car can be flat-towed over a certain speed. I found out that it isn't worth doing in "Moony" (Its manual says not to do it over 25 MPH) or in "Boxy" (Its manual says not to do it over 35 MPH). However, I will switch to neutral under those speeds at red lights if the conditions are viable. |
I've done neutral coasting in every car I have owned for at least the last 7 years. Regular autos, CVTs including an early Insight and an 08 Altima, and now in my 2011 Fiesta, for the last 17k miles in the Fiesta alone.
In some old slushbox designs the transmission will stay in top gear and the torque converter will unlock. My 85 Riviera did this and it took me some time to learn how far it would "coast" when you let off the gas. I loved the car and it averaged 27-28 MPG, but the dang thing put me to sleep if I drove it over 2 hours. The Fiesta does not go into neutral when you put it there is it is moving. You can feel it downshift as the engaged engine speed drops below 1500 RPM, so at 40 MPH, even in neutral you can feel the transmission "downshift" but the clutch stays disengaged until you shift back into gear. I have never and will never do engine off coasting in any auto equipped car. Autos require hydraulic pressure to function as well as for lubrication. If you want to fry your transmission and spend a bundle of money then go ahead and shut off the engine while you are going 60 MPH. I know I won't. The Fiesta coasts down to something like 16 MPH in neutral and still pegs the MPG gauge at 99 MPG. The Insight did 150 MPG down to 16 MPH. The Altima did 60 MPG down to 16 MPH. You can actually calculate your idle fuel consumption using those figures. The Insight went 150 MPG coasting at 16 MPH, os it used 16/150ths of a gallon idling. All 3 cars would go to normal neutral idle speed when coasting, same RPM as they did in neutral sitting still. regards Mech |
If you switch to imperial units, you'll find that it's doing greater than 150mpg. Going downhill in gear feathering the throttle, it'll do 235mpg at 55mph. Which is consistent with the average mpg i get. Meaning i still leave 10-20mpg on the table if i were to EOC every down hill at infinite mpg. |
Speeds as high as 75 MPH with automatics. I have used in gear downhills on my manual VX to keep from being sucked into the rear end of an 18 wheeler coming back from Blacksburg at 85 MPH on a 3 mile 6% grade in the mountains.
Going downhill depends on your speed and whether it is increasing beyond your comfort zone. If your objective is to keep your speed below a certain point than use engine braking (and possibly fuel shut off) to get infinite mileage for your descent. Where I live there are no downhill grades that steep. Only hills where I would use that technique are an hour west of my home, where grades can be coasted for a mile or more further west. regards Mech |
I drive a high milage automatic, it is electroncially shifted, so it isn't like the older style autos. Anyway, bought the car with 225k, currently have 260k, been neutral coasting it quite a bit, and quite often the engine is off. Not really sure how much damage that is causing, since typically the auto transmission will go before the engine in the Toyotas. I'm pretty sure the manual says to not to flat tow as well (does for the 92-96 camry, very similar car, don't have a manual for the corolla).
From my standpoint, if you can put your transmission in neutral, and re-engauge gear smoothly, it shouldn't be stressing the transmission much, engine off vs on is your choise, my car was only $650, I can afford to replace it if needed, and transmissions are around $100-200 in my area, I can do the work myself. |
Rofl didn't even notice the OP's post was LONG AGO O.o
