EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Automobile drag coefficient article on Wikipedia (https://ecomodder.com/forum/showthread.php/automobile-drag-coefficient-article-wikipedia-25681.html)
Xist 04-29-2013 07:16 AM
2 Attachment(s)
As usual, I was trying to study, while my mind tried to think of anything more interesting. Specifically, the absurdity of creating a boat tail for my Forester. It seems like a lot of work for something that increases MPGs by ten percent or slightly more--but that is for a 0.25 Cd Insight!
My car is 0.405!
However, I submit that a boattail equal in length to the car itself is impractical, that is why it is funny!
Good news! I have a point!
http://ecomodder.com/forum/attachmen...2&d=1367234413
Please look at that definition and see if we can make it meet standards. Kammbacks make the world a better place! :)
Xist 04-29-2013 08:34 AM
Using the Template is not always easy. I put more effort into it here: http://ecomodder.com/forum/showthrea...tml#post368673
some_other_dave 04-29-2013 03:03 PM
The Kamm-back is a truncated boat tail--the same shape to start, but chopped off partway back. It gives you most of the benefit of the full tail, but without the full length. The two are not equivalent.
-soD
aerohead 04-30-2013 04:33 PM
tail
A full boat tail would drop the Subie's drag from Cd 0.405,to 0.12.At 55 mph you'd be looking at a 35% mpg increase.
Baron Reinhard von Fachsenfeld/Professor Wunibald I.Kamm both knew the value of a full boat tail and these are included in all their published research.The K-form was just a compromise and concession to length issues during urban driving.
A 50% truncation will not give the drag reduction of a full tail but it is certainly easier to 'park,' and get into a garage.
To address the length issue of a full tail,Fachsenfeld patented the inflatable boat tail which you can see in Hucho's book back in the commercial vehicle section.
NASA's boat tail helped reduce the drag of their Ford Econoline from Cd 0.48,to Cd 0.235.Which leaves half the drag still on the table.
freebeard 05-18-2013 05:19 PM
Shouldn't you be studying? :)
Your Forester's utility would be less compromised with a box cavity or retractable base plate. Look at the Coventry sessions:
http://ecomodder.com/forum/showthrea...tml#post296613
Xist 06-12-2013 09:20 PM
Now that you mention it, I do have a test tomorrow!
Thanks!
freebeard 06-13-2013 12:50 AM
Happy to help.
a8ksh4 06-13-2013 01:23 AM
Good luck on the test Xist. :)
This thread leaves me wondering if there are any wikipedia articles we should be building or updating with the research that's been happening here. It's great having our own wiki, but it would be more accessible if there were an official wikipedia summary of best ways to improve mpg and whatnot. I will keep this in mind for a while and see if I find the inspiration to start organizing some content for this... :)
Xist 06-13-2013 03:38 AM
Thanks!
How would people find those entries?
freebeard 06-13-2013 03:53 PM
One way might be to have general articles created or amplified on Wikipedia, and then an article on Wikipedia about the Main Page of the EcoModder Wiki.
Then add that back into the External Links on the general article pages.
