AutoSpeed Article: Low Drag Car Aerodynamics
AutoSpeed: Low Drag Car Aerodynamics
Originally appeared March 8, 2008. Nice introduction to the aerodynamics of automobiles. Quote:
Hi,
Do you have a link to the entire article, please? |
Ops. Added to first line of initial post.
I wrote to Julian, chiding him for his usage of "laminar" and got this back:
(that one was first published about 8years ago) , I have used ‘attached’. Eg I have done this in Browser Warning. The newer article seems more comprehensive and correct, just leaving out internal flow. I'm not sure if the recommendation to reduce induced drag as a second priority can be done while saving drag if we use wings to fix a shape instead of re-shaping it. |
