AutoSpeed article: spoofing the intake air temp for slightly improved MPG
Everybody's favourite Australian ecomodding site has posted another good one:
The 5 cent modification The subject this time is a mod of the intake air temp sensor, spoofing the engine computer into thinking the ambient temps are lower than actual. The result is more advanced dynamic ignition timing, which if used wisely (ie. earlier light load upshifts, driving with load in a higher gear, or lower speed than usual) can result in improved fuel economy. http://us1.webpublications.com.au/st...10350_13lo.jpg The mod was performed on the owner's Honda Insight, and changes in timing were recorded via an OBD scanner. The usual caveats are mentioned: beware of detonation! Conclusions? Quote:
A better mod would be altering resistance of the coolant temp sensor. That only effects ignition timing AFIK. Air intake temp alters ignition timing and injector duty cycle.
As usual, this mod is a trade off. It will likely increase fuel economy, but result in worse emissions. Then again, who is using WOT all the time? Not many, and especially not us. |
This puts a damper on the warm air intake theory.
No I don't think so. Its pretty obvious that the warm air intake doesn't work.
Based on??? Nothing in the Autospeed article suggests that it's obvious.
I'm in agreement with tasdrouille. The sensor mod PLUS actually increasing the intake temps may result in potentially greater fuel savings than just the sensor mod (assuming detonation is avoided, as usual). Actual results will depend on the particular vehicle's ECU programming & detonation tendency. |
http://autospeed.com/cms/A_109217/article.html Its pretty obvious that what they are trying to keep the intake air as cold as possible. This whole warm intake theory flies in the face of reason and all my experience with 4 different cars. The only rigorous comparison test between cold and warm air intake I can find didn't show an advantage for warm air intake. http://www.metrompg.com/posts/wai-test.htm I think autospeed is on to something with this IAT resistor and I'll give it a try on my BMW. From my service manual: http://farm4.static.flickr.com/3104/...8bf16fe5_o.jpg A 3-5k ohm pot should do the trick. The problem is this engine is not equipped with a knock sensor and the spark timing map is very conservative. BMW recommends using only 91 octane in this engine. I'll use the IAT to advance timing, forward facing cold air intake and a water mist spray to make up the octane difference. A resistor in the engine coolant temp sensor circuit could also be useful to trick the engine into closed loop sooner after a cold start. |
The FE impact of the forward facing CAI does not come from lower IAT, but from the added intake pressure vs stock, or reduction of the pressure drop in the intake if you prefer.
BTW there is sound proven facts behind the WAI Here's what I found out when I was doing my homeworks before going ahead with the WAI. WAI arguments - Pre-heated intake mixture at low rotational speed improves combustion. (Chiu and Horng, 1992) - Specific fuel consumption varies inversely proportional to the square root of the suction air temperature (Nakajima et al. 1969). - Higher ambient temperature is found to increase the flame speed, the combustion reaction rate, the uniformity of the fuel-air mixture and reduce the heat transfer rate though the cylinder walls (Pulkrabek, 1997). - For lower temperatures, only a small part of the injected fuel is vaporized, causing nonhomogeneity. As a result, lower flame speeds, higher unburned mixture, higher hydrocarbons and carbon monoxide emissions, and loss of power are observed (Pulkrabek, 1997; Heywood, 1988). References: Chiu, C.P., and Horng, R.F., 1992, “Effects of Intake Air Temperature and Residual Gas Concentration on Cycle-to-Cycle Combustion Variation in a Two-Stroke Cycle S.I. Engine Equipped with an Air – Assisted Fuel Injection System”, JSME International Journal, Vol. 37, N.4, pp. 957-965. Nakajima, K., Shinoda, K., and Onoda, K., 1969, “Experiments on Effects of Atmospheric Conditions on the Performance of an Automotive Gasoline Engine”, SAE Transactions, SAE 690166, pp. 745-766. Pulkrabek, W.W., 1997, “Engineering Fundamentals of the Internal Combustion Engine”, Prentice Hall, Inc. |
Just stumbled on an article on the 67 Olds Turnpike Cruiser
FTA: Quote:
I've read about cars during the 1950-60's national fuel economy runs using a warm air intake for increased mileage. Some of them seemed to be modified intake warmers used for carburetor de-icing. They also had a much more limited (and thus more controlled) ignition system.
There are engine modifications that can be done to lower the tendency of an engine to ping. One is to radius all the corners within the cylinder/piston cavity...something only practical during a rebuild, but useful nonetheless. - LostCause |
Autospeed has a big following here. Maybe we should ask them to do a story on the subject. |
Maybe I should try that on my 69 Cutlass although I might install a 200R4 trans instead of trying to find 2.41 gears. The camshaft would be an easy swap |
Despite not seeing any results in my own test, I still have the WAI on my car because it'll still help warm the intake more quickly. Quote:
The WAI is actually a common mod on the Insight. Though not as much for reduced pumping losses, but because IAT is tied to lean burn in that car. The WAI permits lean burn at lower ambient temps than without. |
Just curious could this mod be used to force the insight to start off the large battery at lower temperatures? (aka an intermittant switch to make the car think its warm, turn over then disengage.)
My car has had all the grounds replaced twice and still just clicks when trying to start off 12v, I was hoping to find a better way around this issue. Thanx Ryan |
