b2000 electric fan conversion
im planning on doing an electric fan conversion. i have a 97 neon which i plan to pull the parts off of. wondering if the radiator and fan from the neon will be suffient coolant for my b2000 4 cylinder and what problems I might run across. not worried about the ac plan on removing all the ac components from the b2000.
You are using both the fan AND radiator from the Neon? Why not just use the fan and keep the original radiator on the B2000?
will probably wind up doing that actually. just have to figure out how to set it to come on when is required.
You might look here. I'm doing the same only on a Ford Ranger.
http://ecomodder.com/forum/showthrea...sion-7147.html |
