EcoModder.com
-   -   Backfire! (https://ecomodder.com/forum/showthread.php/backfire-13317.html)
elhigh 05-21-2010 09:07 PM
Backfire!
The old pickup and I get along pretty well. We're both getting old so sometimes we make a little extra noise in the joints, slow to get going in the morning, etc. But I never had any parts fall off, and Josie did. $100 later and I have a new el cheapo exhaust system from the cat back.
Josie's carbureted. Fuel cutoff isn't 100% when you turn off the engine; a little gets pulled through as the engine winds down. Here's what happens when you go to turn the engine back on, but don't have enough speed/distance to coast the engine with the ignition off to purge the exhaust pipes.
http://http://www.flickr.com/photos/...n/photostream/
From the rear, looking forward.
http://http://www.flickr.com/photos/...02/4628228600/
The sound it made when it went was huge. I've had backfires before, but dang.
I think I can squeeze it together and clamp the edges shut with a couple of hose clamps. I'm not especially keen to take it back to the original vendor since really it's my fault this happened, no error on his part.
elhigh 05-21-2010 09:24 PM
Okay, I clearly suck at posting photos.
Christ 05-22-2010 12:29 AM
:Rolleyes:
Can you post a link of where they're located in the internets? I'll edit this post to show them for you.
Gasoline Fumes 05-22-2010 07:26 AM
http://farm5.static.flickr.com/4051/...a6df20bbb1.jpg
http://farm5.static.flickr.com/4048/...5226f9c49c.jpg
I have never seen that happen before! My old '84 Civic used to spit fire when you lifted off the throttle and nothing like that ever happened.
chuckm 05-22-2010 09:37 AM
I've never had this happen to me, but I've seen a backfire big enough to do it. A buddy of mine used to have an old car he could make backfire pretty much on command. We were driving under an overpass and I was in the rather, umm, exciting position of being the car behind him when he did his thing. In a quick sequence, he went from ~30% throttle to idle, which let it lug for a second, punched it to the floor, then back to idle. Unburned fuel made it through into a exhaust system that was a bit rusty (read: there was at least one hole eaten through), where it didn't remain unburned for long. Let me tell you, this underpass made a VERY impressive echo chamber and it was dark enough to clearly see the fireball erupting from the rear of the car. It sounded like being next to a double barrel 12 gauge shotgun.
If you know anybody with a welding rig, clamp it closed and weld it shut. TIG is best here, MIG second, and stick is just a maybe (and only if you have the right type of rod).
elhigh 05-22-2010 10:34 AM
Okay, those are my pictures. How did you do that?
Gasoline Fumes 05-24-2010 11:28 AM
I don't know how it got there, but you had an extra "http" in the photo URLs.
