Old 05-18-2019, 02:10 AM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Balance shaft delete (better MPG observed)
I just removed the balance shafts from our 2006 rav4 2.5L and I wish I had done it sooner. The difference is amazing. More power, better response, less throttle needed, and quieter.
It used to down shift on the hills around here and the rpm's would go way up. Now it just rolls right up the hills like they're not even there. Night and day difference.
I hope we don't get a speeding ticket, because it takes barely any throttle to maintain speed. It's going to take some getting used to for sure.
The engine is much quieter now. There was some "clattering" that we attributed to engine wear, but it's gone now. It had to be the shafts making noise. We can now whisper with the engine running, both inside and outside the car. All you hear is the injectors clicking and the exhaust.
The mileage should go up some too.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following 2 Users Say Thank You to IsaacCarlson For This Useful Post:
Gasoline Fumes (05-19-2019), MetroMPG (06-11-2019)
Old 05-18-2019, 09:25 AM   #2 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Do you know the design intent of the balance shaft? Was it for idle vibration?
Old 05-18-2019, 10:01 AM   #3 (permalink)
Team Pontiac
Yes, it was just for comfort, but you'd have a hard time even knowing it was there.
1991 F-250:
Old 05-18-2019, 10:51 AM   #4 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Such is the case for a lot of modern four cylinder engines... they’re fairly smooth even with the shafts deleted...
Did you physically remove yours or were they powered by their own chain which you could cut/remove?
My current Ecotec project...
My last Ecotec project...
Old 05-18-2019, 10:54 AM   #5 (permalink)
Team Pontiac
I took them out. They were gear driven by the crank. They have plastic gears.
1991 F-250:
Old 05-18-2019, 11:17 AM   #6 (permalink)
Team Saturn
Plastic gears? WtF, Toyota?
I’ll have to buy a kit for my car, my balance shafts are ran on a chain that also runs the water pump...
Old 05-18-2019, 11:19 AM   #7 (permalink)
Team Pontiac
I know, I was shocked as well.
The engine was making clattering noise and I figured it was just showing age.
It was the shafts! It's sooo quiet now.
1991 F-250:
Old 05-18-2019, 12:10 PM   #8 (permalink)
Team Saturn
Hmm... (looks over ZZP performance catalog)
Old 05-20-2019, 02:27 PM   #9 (permalink)
90 day: 40.51 mpg (US)
I'm almost done putting a Honda 2.4L in my Insight. One of my first mods to the engine was to delete the balance shafts. These weight around 11lbs, are part of the oil pump assembly, and spin at twice engine RPM because their purpose is to minimize second order harmonics which would be transferred through the engine mounts. They don't do anything for engine longevity and add both friction and a lot of inertia to the engine.
I'll post a video of it when I'm done, looking like Thursday.
Old 05-20-2019, 10:53 PM   #10 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Counter argument:
https://www.jackstransmissions.com/b...balance-shafts
Since balance shafts spin at higher than crank speeds, it makes sense that they can wear out their bearings before the crank bearings, leading to noise etc. So removing worn balance shafts can 'improve' an engine.
