Old 10-21-2008, 04:47 PM   #1 (permalink)
Timing a 93 civic dx...
Tuned my 93 civic dx today and was looking at a confusing chilton for timing procedures and if I understood it right it said to jumper the grn\wht and the brn connector behind the passenger kick on '92s but not to jumper 93-95s. I went ahead and warmed it up and set the timing with no jumper and it seems to be running well. Somebody also suggested dissconnecting the negative battery lead for a minute after I was all thru to reset the computer. Any thoughts? Thanks! Rick
Old 10-21-2008, 05:51 PM   #2 (permalink)
I don't know the 92+ cars specifically, but if you followed the procedure and it's running fine, sounds like you did it right. You can reset the ECU if you really want to (on the 88-91 cars you pull the fuse for the hazard lights to do that, I think!) but it shouldn't be necessary.
-soD
96 Civic DX HB vs civic HX EngineeredCivic EcoModding Central 4 09-21-2008 08:30 PM
Unmodding my '91 Civic DX ohmycivic EcoModding Central 22 07-28-2008 02:08 PM
Civic HX or DX GregM EcoModding Central 7 07-22-2008 10:27 AM
Gas tank size on '93 Civic DX hatch ? Cd EcoModding Central 0 06-06-2008 10:44 AM
'93 Honda Civic DX Coupe -- Good Project Car? RH77 The Lounge 5 04-01-2008 09:25 PM
