EcoModder.com
-   Fossil Fuel Free (https://ecomodder.com/forum/fossil-fuel-free.html)
-   -   Battery breakthrough (https://ecomodder.com/forum/showthread.php/battery-breakthrough-20727.html)
payne171 02-27-2012 10:16 PM
Envia battery breakthrough gives General Motors lead for affordable electric cars | Motoramic - Yahoo! Autos
Maybe this is the battery advancement that makes the EV and/or plug-hybrid for the average American to put one in their garage.
deathtrain 02-27-2012 11:35 PM
you mean after the failure of the Volt a Government Motors (GM) backed company has a "breakthrough" say it is not so......
cfg83 02-28-2012 12:47 AM
payne171 -
Pretty cool. I hope this pans out. Here is the Envia website :
Envia Systems | Powering the next generation of electric vehicles
CarloSW2
sendler 02-28-2012 08:21 AM
Great job. Dialing in the nano coating micro- porosity to exactly fit the shape of the ion molecules is going to be the big step forward. This results in improvements in density and also a huge increase in cycle life which is just as big a hold up in people adopting plug ins and hybrids. When cycle life can hit 5,000, we will have a battery that no one will be afraid of. Fortunately, improvements in power/ mass density will go hand in hand with increased life cycle due to the ions not cracking and forcing their way into pores of the electrodes that are too small. Then the last hang up will be price.
user removed 02-28-2012 08:49 AM
We have been anticipating the "breakthrough" in battery technology for decades and billions in financing. I will follow this development closely, especially considering that they are promising a significant increase in energy density, while also promising a significant reduction in cost, the best of both worlds.
If this becomes reality, then the US govt should step in and make sure the availability of these batteries is universal and possibly with much of GM stock still owned by the govt, a deal could be struck that would allow GM to license the technology to everyone at a reasonable cost while lowering or eliminating their obligations to the govt.
regards
Mech
Daox 02-28-2012 09:55 AM
I saw the same article yesterday. If you look at their site these batteries only seem to be tested to 500 cycles, and the AH capacity pretty drastically drops off during that time (a good 20%+ loss). I realize the weight benefit, but they will drastically need to improve cycle life in order to make this main stream.
http://enviasystems.com/images/45ah-cells.png
payne171 02-28-2012 10:42 AM
I agree that it would be better if GM was willing to license the technology to other manufacturers, but dictating a "reasonable" price is trouble. I will ignore the free market because I don't think GM deserves that right after the bailout, but if the government forces a price control on the tech, it will basically tell GM and Chrysler not to bother with that type of research anymore. Furthermore, GM can charge what they want, and competitors can either pay the price or they can massively increase battery research to stay competitive. Either one is good because it either encourages the biggest car maker in the world to continue on this route, or it will increase the spending on battery research, likely both.
esoneson 02-28-2012 11:29 AM
These cells will be used in a pack that provides 300-400 miles each charge.
500 cycles will yield 150,000 to 200,000 miles at 100% discharge. And at 70% discharge it is 105,000 to 140,000 miles.
How long will it take you to drive that many miles?
I see no need for any cycle life improvement especially with the low predicted cost to get your vehicle up and running with no or little 'range anxiety'. And by the time you drive over 100,000 miles there will be a better, less costly replacement available to you.
sendler 02-28-2012 01:32 PM
I don't think you can add it up that way. We are at 70 miles range now with the Leaf and MiEV. The range with the new battery will be 150 miles max. And, regardless of the range that is used, I would actually think a lifetime of 500 cycles would be much closer to, 500 charge cycles even if the discharge was only 50%. I would have to hope for much more than 500 cycles. The nano technology should take us way past that on the first generation as this concept is way more important for longevity than power density.
oil pan 4 03-01-2012 06:42 PM
Is this scale able?
That means is this cheaper than just building a bigger battery and replaceing it sooner?
A lot of these advancements seem to only help the cell phone, laptop and tablet makers.
sendler 03-01-2012 06:52 PM
Originally Posted by oil pan 4 (Post 290443)
Is this scale able?
Bigger starts to get too big and heavy to put in a car or motorcycle.
DJBecker 03-01-2012 10:22 PM
We do seem to be right on the edge of usable for automotive use.
Lead-acid has low cost for the capacity, but the weight means that you can only build a slow or short range vehicle. A 30 mile range at highway speeds means that you are at a 2C discharge rate (at best). That drives the cycle life and efficiency way down. Adding battery capacity dramatically increases weight, requiring bigger everything, eliminating much of the range gain.
Current LiFePO tempts us with a possible life of 5000 cycles, but only if we discharge at a 0.3C rate. That means a car with at least 3.3 hours of range, which means batteries are more than half the vehicle weight. Most builders compromise with a 1 hour range and a significant discharge with every drive, accepting a likely sub-500 cycle life.
A 3x increase in capacity at the same weight would be a game changer. You could put in enough capacity to not do a major discharge with a short trip, or stress the battery at highway speeds. And once a normal range battery is no longer more than half the vehicle weight, you can increase range without doubling the size of everything.
That said, I haven't seen enough details to believe that this is really a breakthrough in power density.
sendler 03-02-2012 07:59 AM
The new nano coatings will improve cycle life and damage free current rates quite a bit.
oil pan 4 03-02-2012 09:09 PM
I need to get a way to make my A123 LiFePO4 starting batteries last.
yostumpy 03-06-2012 04:41 PM
Now and again i get invited to various lectures at the local uni, and i went to one about a year ago, all about renewable energy. Most was a bit over my head, but the lecturer was into hybrids and battery power, and he said that some major breakthro's were coming in the battery world. he said, that the next BIG thing on the horizon, that was being developed beyond its normal means, was the 'air battery'. He gave comparisons for power to weight ratio, efficiency and longevity, and showed via 3d models how it worked, but i've forgotten now. it looked very promissing, but he said it would be a few years before anything was seen in public.
Air-Hybrid 03-07-2012 10:28 AM
air-battery-to-let-electric-cars-outlast-gas-guzzlers (newscientist)
:thumbup:
SOUL-DRIFTER 03-29-2012 08:51 AM
Envia Systems battery breakthrough for affordable 300 mile range electric cars
This is the future.
Do away with the combustion engine and go all electric.
Where I work is a 40 mile drive one way, up and down hills and curves.
A long range electric car would be the ticket.
We already have a local station that offers an electric car charging spot.
Lithium battery startup company Envia Systems plans to announce tomorrow, at the ARPA-E conference, development of a high energy density lithium battery (400 watt-hours per kilogram) which could be the tipping point enabling long range affordable electric cars. Long range electric cars have been possible for quite awhile, Solectria built one in the 1990's, and Tesla Motors has been selling the Roadster and will soon be selling the Model S with battery packs sufficient for 200-300 miles of all electric driving range. What Envia brings to this is higher energy density and lower cost, a combination which would make for an affordable, long range, electric car with a 300-mile range and a price around $25,000 to $30,000
