EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   Battery light is ON only on first start (https://ecomodder.com/forum/showthread.php/battery-light-only-first-start-10833.html)
darkmaxx1 11-02-2009 11:23 AM
Hello,
My car is being weird recently.
When I start it, the first time, the battery light is ON. (cold mornings)
I turn it off, then I restart it. the battery light is gone :eek:
What would make the light of the battery turn on only in cold mornings and at the car's first start on the day. :confused:
wagonman76 11-02-2009 12:23 PM
Maybe the voltage regulator in the alternator going screwy?
My old Cavalier had a similar problem. Sometimes when starting the volts light would be on and it wouldn't charge. The mechanic showed me how to jump 2 wires at the alternator to give it a kick in the pants and get it to charge. It became so common that I wired a switch up to the dash so I didn't have to pop the hood every morning.
NiHaoMike 11-03-2009 01:12 AM
Might be a bad relay.
darkmaxx1 11-05-2009 09:52 AM
It is the alternator. When the battery light is on, it charges 11.3v and then when we restart again, it is 14v.
NiHaoMike 11-05-2009 09:57 AM
Looks like an intermittent fault in the voltage regulator circuit. Pull the board and post a picture of both sides for more troubleshooting.
darkmaxx1 11-05-2009 10:09 AM
I didn't mention, but I've replaced the alternator on July 2009, and it is on warranty. (except labor XD)
They will replace it next Friday (13 october)
NiHaoMike 11-05-2009 08:06 PM
In many power supply circuits, a common cause of intermittent failure to start up is a bad controller Vcc supply capacitor or resistor. If the resistor increases in value or the capacitor becomes leaky, the Vcc never gets high enough for the controller to start.
