Old 01-20-2010, 09:04 PM   #1 (permalink)
24v Motor question...Will it work?
I have access to a 24V forklift, that is complete. My question is will the motor work for a EV? How much voltage can the motor take and what do I look for? I am assuming the motor should be 8" to 10" diameter for strength and capacity. I would like to take it to freeway speeds, so can this be done by using a motor controller in the 144V range? Essentially I am going to pirate the cables and motor, what else might be applicable if anything. Thanks
Old 01-20-2010, 10:26 PM   #2 (permalink)
I'd say it can probably be used, but its never a certainty. Weight is another factor, the more it weighs, the better it can handle increased power output (generally speaking). Take a look at the brushes and see how large they are. That will also give you an indication of how much amperage they can handle.
Make sure you grab things like the contactors, copper bus bars, and fuses.
Old 01-21-2010, 02:22 AM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
144 volts in to a 24 volt motor? the windings are to large of wire and way to short, something is going to burn up quickly, read a little about motor basics before trying something like that.
Old 01-21-2010, 06:57 AM   #4 (permalink)
We have guys using 36V motors @ 144V with no problems in the local club.
Old 01-21-2010, 08:15 PM   #5 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I wish a GOOD walkthrough of evaluating and modifying a motor DIY would be made, I have a little 5hp 6 3/4" motor designed for 48v. I have been told repeatedly it dies at 96v as people have killed it at 96v.
Trouble is I do not know how the people made it fail, was it RPMs? Was it heat? Never can find out.
Anyway do most of the guys in the local club advance the brushes at HV?
Do Pulstar Pulse plugs work? Z man DIY / How-to 94 12-29-2013 10:51 AM
Will this work for my metro thefirebuilds General Efficiency Discussion 4 12-27-2008 11:45 AM
News: GM's chairman - "small cars don't work in this country" MetroMPG General Efficiency Discussion 32 11-19-2008 06:50 PM
Universal AirVortex - Anyone Use These? Will They Work? LastBoyScout Aerodynamics 1 09-06-2008 09:11 AM
Carpooling really does work silverknight General Efficiency Discussion 6 08-01-2008 03:43 AM
