Old 12-20-2016, 02:18 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
Running on gas fumes
Any of you try this?
Old 12-20-2016, 02:34 PM   #2 (permalink)
I've done something similar to this on a carbureted engine.
It works after a fashion and is interesting. However, at some point, the light, easily evaporated components of the gasoline are used up and the engine cannot run on the thinning fumes. At that point you start fooling with heating your fuel to evaporate more of it. In the end, you end up with those hot vapor carbs others have built.
Old 12-20-2016, 02:36 PM   #3 (permalink)
Wayl sheoot, thayt's smeooth tee hee!
Why don't he driaaaave it?
Old 12-20-2016, 03:24 PM   #4 (permalink)
That's a surface carburetor. Technology abandoned more than 100 years ago for the reasons stated above.
Old 12-20-2016, 04:21 PM   #5 (permalink)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Shenanigans.
Old 12-20-2016, 04:26 PM   #6 (permalink)
What is a Pogue carburetor, similar principle?
Old 12-20-2016, 04:53 PM   #7 (permalink)
The Pogue carb extended the idea of producing vapor to the extreme.
If you look up the original patent on Google, you will only get part of the story. What it doesn't tell you, and the supporters won't tell you either, is that there are several components and driving techniques that make the carb effective.
The car Pogue used was stripped of extra seats, spare tires, upholstery, etc. The carburetor needed a large heat exchanger that took up a large volume that extended into the passenger spaces. The chosen route was a largely flat, easy path and the car never exceeded 40 mph as . . . it could go no faster! Starting the car was problematical and a common carburetor was used to run the vehicle until enough heat was available. I got this information from a symposium back in the 70s where a credible witness to the event gave his account. This account is buried by the pro-200 mpg crowd.
Look up Pogue carburetors on Google Images and you will get dozens of pictures of the complex carburetor. In and of itself, it is a marvel. The scale of it is not apparent, but it is much larger than your usual carburetor.
https://www.google.com/search?q=pogu...sAQIGQ#imgrc=_
