EcoModder.com
-   -   Bed Cover/Cap questions (https://ecomodder.com/forum/showthread.php/bed-cover-cap-questions-17110.html)
hat_man 04-29-2011 07:22 PM
Hello everyone,
I have a couple of questions about how to "control" the bed of my truck. The biggest one is where to find coroplast now that "election season" is over. The party headquarters were rather stingy around here and didn't want to part with any good size pieces. Said they had been paid for by candidates. I said if I had called during elections you would have given them away if I put it in my front yard. No dice, grrrrr! I have an idea for a real cheap DIY "tonneau" cover made from coroplast but can't find any.
The other question is, if that idea doesn't pan out I think I am going to try a full on bed cap. After deleting the side mirrors though I think I would need to make a good portion (or all) of it out of something clear. What could I use that isn't going to put a huge dent in my wallet? Plexi-glass isn't all that cheap around here. The piece for my grill block (14x36) was almost $15. I estimate two 4'x8' sheets to do the whole thing. Does anyone have a line on cheap, clear material? Plexi or something else.
Thanks for the advice.
Hat_man
Joenavy85 04-29-2011 07:43 PM
look up local Sign shops, most around me in Northern Illinois sell it in 4'x8' sheets, and usually will cut it in half (or however you want, involving stright cuts) for free. i get mine cut into 2 - 4'x3' sections and 1 - 4'x2' section, for $20. i'm not sure about color availability, it will vary from shop to shop
hat_man 05-02-2011 09:13 AM
Where are you at in N Illinois Joe? I'm near Dixon.
