Old 07-12-2008, 10:11 PM   #1 (permalink)
SilverStang - '00 Ford Mustang
90 day: 22.23 mpg (US)
Aerodynamic help 2000 Ford Mustang
I bought this car the way it was at 60k miles on it, everything you see was included with the car, I made no modifications. Now my question is what do I do to make this car more aerodynamcally suited if it isn't already, which I doubt it's very aerodynamic at all. I was thinking of filling in the grille and somehow putting on wheel skirts, anyone have suggestions of what type of material to use? SHould I remove the stock wing, and if I do so would I cause rust to happen, I really don't want holes in my car.
snipes912 - Photobucket - Video and Image Hosting
I want more MPG anyway I possibly can get them, I do practice good driving techniques and I accelerate slowly and i do not drive past 55MPH. I get about 20MPG now, is there any way to increase this further, I think I am getting the most I can out of it now by drivng slower and coasting.
Finally got my 20% above EPA
Last edited by 2000mustang fan; 07-12-2008 at 10:27 PM.. Reason: pictures didn't appear
Old 07-12-2008, 10:30 PM   #2 (permalink)
Img Codes pics
Old 07-12-2008, 10:53 PM   #3 (permalink)
Danger Ranger - '01 Ford Ranger Edge 4x4
90 day: 14.52 mpg (US)
Moms car - '05 Ford Freestyle Limited
90 day: 21.92 mpg (US)
Mistress - '10 Harley-Davidson 883 Sportster 883 Iron
90 day: 42.53 mpg (US)
Send a message via AIM to meemooer
Cover them holes in the front bumper and body kit. It's killing the aero.
But looks good for a 3.8
Randy
Old 07-12-2008, 10:59 PM   #4 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Return the Tornado and Ethos unopened and get your money back. They're junk.
Save up and order a ScanGauge II, a real-time monitoring device that can tell you what your instant and average mpg are - really the best on-the-fly feedback for your driving habit training.
Try doing a grille block - there's a lot of opening below the bumper on your ride, so closing off the opening above could allow a smoother flow over the hood. Smooth = good.
Old 07-12-2008, 11:27 PM   #5 (permalink)
So how do I cover up the holes in the front bumper, grille and body kit with what material, and without damaging my car's body kit. and would wheel skirts work at all? can I achieve better mileage without shutting off my engine while coasting? How does everyone get so high mileage without products, cause it seems impossible cause all I can get is about 20MPG, I will return the ethos and tornado, but they probably will give me a hard time to return them right? I guess I'm going to get a scangauge 2 can I pick one up at a stor or do i have to order it online? thanks, everyone.
also how do you guys get that EPA rating thing as your sig i put it there but mine won't show up how do i get it to appear?
Old 07-13-2008, 12:19 AM   #6 (permalink)
NismoMax80's Avatar
Max - '04 Nissan Maxima SE
90 day: 24 mpg (US)
click the 100+ hypermiling tips link on the top.
use corplast for the holes like i did.
my current project
Old 07-14-2008, 03:42 PM   #7 (permalink)
Master Novice
elhigh's Avatar
When they ask you why you're returning the items, just tell them you sold the car. Sure it's lying, but they were lying when they described the lofty benefits of their crappy products, so you're even. You're still out shipping and handling, but that can't be helped.
There are a few stores that sell ScanGauge II's, but you'll have an easier time just picking one up from eBay. It'll cost about $165-175, plus S&H.
As far as getting big mileage, you're kinda starting from behind - the Stang is really a sports coupe, and kind of a heavy one at that. Generally Mustangs are set up for stoplight speed - pulling away fast. They aren't usually set up for long-legged highway cruising. Find out what your axle ratio is, and your top gear ratio - those are good to know. Then look up your engine's power output curve. It's been my experience (I'll probably get flamed for this) that running your engine at the revs where it develops its torque peak is usually a pretty happy place to be. Just cruising around you aren't going to be generating anything like peak torque, but still.
Change your driving habits first and see what results you get. I refilled my truck this weekend and got 39.5mpg - I was so thrilled I forgot to be annoyed it wasn't 40. We'll have you looking down on 25mpg with disdain in no time.
Video: tuft testing (rear) 1993 Ford Mustang notchback MetroMPG Aerodynamics 12 02-05-2011 09:40 AM
Think you can hypermile? Ford contest will give the winner a car * MetroMPG Hypermiling / EcoDriver's Ed 6 08-04-2010 08:31 PM
I'm new and I would like some Ideas please for a 2000 Mustang V6 2000mustang fan EcoModding Central 28 07-14-2008 05:38 PM
1998 Ford Mustang V6. Stanger98 Introductions 11 07-04-2008 06:27 PM
Ford, making money? It must be a mistake... SVOboy General Efficiency Discussion 3 04-28-2008 09:28 PM
