Old 04-12-2009, 10:00 PM   #1 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
rear veiw cameras.
I was at a local store the other day and noticed that they had these cameras for sale for $89.99 and thought that looked just like what someone might want if they had alot of aero mods on their vehicle.
I have not tried these yet, but it's wireless and looks to be pretty compact with a reasonably clear image on the one set up as a store display.
Old 04-13-2009, 12:36 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Thanks for the link...
I'm tempted,
Old 04-13-2009, 12:42 PM   #3 (permalink)
NewBlue - '07 Honda Civic EX
90 day: 38.13 mpg (US)
The Better Half - '97 Ford Ranger XLT
90 day: 25.84 mpg (US)
I was looking at those last summer, they do look pretty neat, they are setup to turn on when the back up lights are on so you'd need to hard wire power to it. The other thing is you can only run one, I had thought about mirror deletes with two of these but they will interfere with each other. I have also heard wifi and other RF can mess up the images so I never bought them to try it.
2007 Honda Civic Ex
Second Goal = 50mpg
First goal = 40mpg Goal Achieved 3 tank average over 40mpg
Starting point 30mpg ready...... GO.
Old 04-13-2009, 12:50 PM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Coyote X has cameras for side view mirrors in his Metro. Not sure what style/kind he's got.
Old 04-13-2009, 12:55 PM   #5 (permalink)
I've seen them too - in WalMart, no less. But for me wireless is the problem. I just wouldn't trust it to be reliable enough for a rear-view mirror replacement.
Old 04-13-2009, 01:02 PM   #6 (permalink)
If you could find a good price on a small LCD you could setup a webcam to a laptop in the trunk then hardwire the LCD up front. If you did this you could probably have a camera on each side running back to the cheapo trunkputer then either run two small LCD's or one LCD setup with a split screen for each side.
Cost would definitely be higher but you'd eliminate the wireless element and get rid of your two exterior mirrors.
You would have to do some rubber mounting of the trunkputer and definitely need a rugged laptop HDD or run a solid state hdd to keep it alive for more then 2-3 trips (at least in the northeast where potholes can eat metro's)
2007 Honda Civic Ex
Second Goal = 50mpg
Old 04-13-2009, 01:11 PM   #7 (permalink)
Hi,
What sort of RF signal is it using? Is it Bluetooth?
Old 04-13-2009, 01:13 PM   #8 (permalink)
I believe it was bluetooth, I'll research and edit I found it on a spec page at one point.
# can you use two camera systems at once? Will they interfear with each other or is there a way to set the channels? Thanks
* It should be fine to have two cameras mounted on separate vehicles, as it is rare that both vehicles would be in reverse at the same time. However, the cameras will interfere with each other if both of them are active at the same time. The result is that the display will get confused about which source it should read from.
That is from the VR3 camera system which is the one I looked at last year, I can't find anything about "peak" which is the one you linked.
http://sewelldirect.com/VRBCS300W-wi...kup-camera.asp
And i'm pretty sure I read somewhere that it was bluetooth but I can't seem to find it now.
2007 Honda Civic Ex
Second Goal = 50mpg
Old 04-13-2009, 03:29 PM   #9 (permalink)
I suspect Bluetooth is way too slow for video.
Old 04-13-2009, 03:35 PM   #10 (permalink)
My bad, it's not that slow
Bluetooth - Wikipedia, the free encyclopedia
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Dual Fuel, electric rear wheel drive, gasoline front wheel drive bucknmusky DIY / How-to 42 12-27-2012 01:59 AM
Interest in rear wheel power (electric) bwilson4web General Efficiency Discussion 15 01-23-2011 03:41 PM
New steering system concept to minimize aerodynamic drag Blue Bomber Man Aerodynamics 37 03-24-2009 02:19 AM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
