Old 08-02-2010, 01:22 AM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 27.11 mpg (US)
Windshield wipers?
Ok, I was always a rain-x windshield wiper fan (the normal ones, not the latitudes) they always works decently, id give them a 8.5/10
Well since I got a new car I was going to get the new rain-x latitudes but they didn't have my size so I got the Michelin Radius wipers instead thinking they were probably the same anyways...
Well I put the wipers on and, well... They sorta suck... Every part of the windshield was perfectly wiped EXCEPT the area under where the wipers clip on, like maybe my arms dont push them down hard enough so there is a giant streak where it misses every time...
Think im going to take these back... Any ideas on which wipers are best?
Old 08-02-2010, 01:31 AM   #2 (permalink)
90 day: 34 mpg (US)
Or, now that I think about it, do you guys think that maybe I should just wait it out, the wipers may just be stiff from packaging and need to form to the windshield for a few days before I am quick to judge
Old 08-02-2010, 01:42 AM   #3 (permalink)
Maybe clean everything off in the meantime too.
Old 08-02-2010, 01:48 AM   #4 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
I don't use wipers for rain or snow. Just for wiping bugs off.
Keep the windshield clean and use just a hint of rain X and it will be great. Even in the hardest of rains.
Old 08-02-2010, 05:02 AM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The Bosch Aerotwin will be hard to beat (on anything but price).
Old 08-02-2010, 12:29 PM   #6 (permalink)
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
i added larger wipers to my car. this made a bigger difference then the brand. i have been looking into adding a wing to the wiper arms to use wind pressure to force the wipers down. i have seen this wing stock on some cars.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
Mod for wipers (maybe) hat_man EcoModding Central 15 06-17-2010 04:32 PM
Windshield dimples Piwoslaw Off-Topic Tech 7 09-28-2009 09:49 PM
Windshield wiper suggestions? SVOboy Off-Topic Tech 26 08-18-2009 09:40 PM
Windshield wipers lockout in vertical position zman General Efficiency Discussion 6 04-26-2009 09:41 PM
One Windshield Wiper Instead of Two Wayneburg EcoModding Central 22 05-08-2008 02:04 AM
