Best FE uphill?
What is the best way to climb in a small 4 cylinder, low revs high gear with say 1/3 throttle or let it rev at less throttle but in lower gears.
Thanks all |
Low revs in a higher gear will burn less fuel than higher RPM in a low gear with a fuel injected vehicle. A carburetor is another story. It can go either way with a carb, depending on how the carb jetting is set up.
If you can find the BSFC (Brake Specific Fuel Comsumption) plot for your engine - it will show you the "Sweet Spot" for efficiency - tends to be higher load @ lower RPM.
I have not been able to find one for my Nissan - checked several forums. I try to max every downhill i can for the next uphill. when taking on a hill from a stop - I try to accelorate compreable to that on a level road ( so there is a little more fuel used overall - but then i am "thinking" the same) and i try to anticipate the crest of the hill and back off to coast over. Steve |
I do about the same as Doofus. A hill is a hill and you are stuck climbing it. A little run up it whether from a flat road, or a previous downhill, will help get up it with little MPG loss. Back off the throttle as you go up, or back off near the end and "coast" up will be good. Now a big long hill - another story. Stay in your overdrive gear, low RPMs (don't get crazy though) and steady throttle all the way up; towards the end you want to gradually back off the throttle and get over the top enough to stay in your overdrive gear. If you have to down shift due to timing the top wrong, don't fret - it still works out ok with not a whole lot of MPG loss.
Some of my hills are rolling grasslands, so I can sometimes gain a tenth of an MPG from hill to hill if I do it right. |
I'd say a good rule to follow on hills with a manual transmission; Stay in the highest gear you can, using around 50% thottle without lugging the engine. Ian |
Thanks for the feedback, At the moment I drive hills the way eveyone described, just thought I should check as the correct answer is not always the intuitive one.
We have LOTs of hills down here so it is a major part of my driving. I am hoping to get a scangauge but I am trying to find out if my car supports it fisrt, it has the socket but I am not sure on the protocol. |
