Electric wouldn't work then.
Disagree. 100 mile range is 'easy', 300 mile range is possible -- it's done by commercial offerings and the wrecking yards are filling up with OEM components.
I have my own theory; the Arcimoto FUV has the complete drivetrain, suspension and steering between two bulkheads 18" apart with the same track and 100mm bolt circle as a Beetle. The inverter/controller stack would land about where the Beetle's fan was. The 68 HP is twice the original 36 HP (needed with a single speed).
The key is efficiency. Here's a beetle with suspension narrowed, body sectioned crosswise, and widened fiberglass fenders. Needs a boat tail. Narrowed front beams are commonly available. The rear axles are automatic lefts on both sides because they are 1 1/2" shorter but the torsion housing would need to be cut and shut. (this wouldn't work with the FUV conversion)
Here's where you reduce frontal area
Replace the heater channels with flat plate and chop the top by quartering the body.
