Best place for a replacement Civic alternator?
I have been trying to price the least expensive voltage regulator. Autozone had one for $170, but places like Majestic offered OEM ones for less, but I needed some other parts, and was trying to figure out everything that I needed, and the least expensive way of replacing all of them, as I went into finals. Then I drove to my parents' house.
I took a young lady to dinner and afterwards, since this is a small town, and she said there were not any more movie showings, I took her for a drive, and was pulled over in an even smaller town. The Officer said that I was going "slightly" over the speed limit and my tail lights were flickering just barely noticeably. I told my date that I was waiting until after finals to replace the voltage regulator, which is apparently part of the alternator. She said that a new alternator would probably be cheaper. Majestic and other places charge $700 for an alternator! Autozone and O'Reilly have alternators for $103! They are remanufactured, while I can purchase used ones back in the valley for $35-50. Should I just get one from O'Reilly? |
It's hard to justify $700 for OEM for an alternator. Even if you need to replace it 3 more times compared to the OEM, the box store brand is still better value. I've had a replacement alternator and distributor from a parts store for years and have not had any issues.
Have you checked local salvage yards?
I can not emphisize this enough. When you buy a rebuilt alternator, have them test it in the store before you leave!!!!
Twice, I replaced a Civic alternator only to have the replacement fail within a week. My last one was OEM. They may joke about it being factory tested. I don't care. Test it again before you leave the store. |
If you plan on keeping the car for along time consider the lifetime warranty option. At least you won't have to buy another one.
regards Mech |
Alternators are fairly simple machines, I would troubleshoot it first. At least see if you have any brushes left and replace just those if not.
Before throwing money at it, are you sure it's the alternator?
Honda uses something called an Electronic Load Detector (ELD) to vary the alternator output. If this is acting up, you could see symptoms similar to a bad alternator. It's especially noticeable if you have a stereo or added some auxiliary fog lights that are not sensed by the ELD (it's located in the main fuse box). With a large current draw that is not detected by the ELD, the alternator may not be driven hard enough to balance out your power consumption. |
Also make sure you have good grounds everywhere.
regards Mech |
Strange. This is almost a direct quote from http://ecomodder.com/forum/showthrea...tml#post424066, but I started a new thread because I did not receive any response.
What are the chances of them being OEM, though? Quote:
http://www.hondapartsnow.com/diagram...shi-455062.png At least, according to AutoZone. Quote:
Mom keeps saying that I need to fix the electrical system before I have the AC fixed. Then there are things like needing to figure out why I cannot charge my cell phone. It might just be a fuse, but this might be blowing the fuse. |
While a visual check is better than none it is best to use a volt meter. Just as easy to clean without checking and take very little time. I recommend you clean the ground using a small rotatory tool with with a brass brush, less likely to remove the coating protective coating from the connectors. |
Make sure the battery is good and fully charged. If the lights are still flickering with a good battery then I don't think the alternator will solve that problem. You can check the grounds with a volt meter but a visual inspection and no ground cleaning is a recipe for a later post "Well I replaced the alternator (or regulator) and it still has flickering lights".
Replacing only the regulator leaves you with an alternator that has seen many miles and is still a potential failure. regards Mech |
I do not think that I mentioned this: https://scontent-b-dfw.xx.fbcdn.net/...85837812_n.jpg |
A remanufactured alternator, even if it's not OEM, might still be a good cost-effective option. Anyway, nowadays it can often be cheaper to buy the stock item quoting by the part number (issued by the supplier, not by the automaker) instead of buying for a specific car.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
