EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Best Temp. Gauges (https://ecomodder.com/forum/showthread.php/best-temp-gauges-18149.html)
Diesel_Dave 07-13-2011 02:18 PM
Best Temp. Gauges
I'm looking into adding some heaters to my truck to improve the warm-up FE. I need to monitor the temps to see how well I'm doing as well as to make sure I don't overheat anything.
My question is what are the best temperature gauges to use without spending a whole lot of money. Since I don't need high accuracy, I'm thinking mechanical-type gauges are probably best (and fairly inexpensive).
What are other people's experiences about the best types, brands, etc?
Daox 07-13-2011 03:20 PM
I'd just get a ScanGaugeII or ScanGaugeE. It'll tell you all you need to and more, plus it'll pay for itself with the fuel savings you'll see from using it.
TheEnemy 07-13-2011 04:41 PM
Ready-Made Insulated Thermocouples, Models 5TC-GG, 5TC-TT
$60 for 5 K type thermocouples, can be placed practically anywhere and most decent multimeters can read them.
edit: I think you would still have to get connectors.
Diesel_Dave 07-13-2011 05:01 PM
The SG can't tell me temperature of things there aren't sensors for. I don't believe I have temp sensors for oil or tranny temp and I know I don't have anything in the axle.
gone-ot 07-13-2011 05:29 PM
...how "hot" are the "places" you need to measure? 100ºF, 200ºF or more?
...if anticipated temperature(s) are less than 150ºF, buy a cheap, battery-powered, remote weather sensor with a remote sensing "bulb" from Wally-world or Tarjay and tape the sensor to whatever it is you want to measure.
...if the sensor overheats or melts, simply buy a replacement plug-in sensor.
