Best use of a Scangauge?
I've got a Scangauge(II I believe) and at the moment I've got it showing current MPG, AVG MPG, Voltage, and Coolant Temp. My vehicle doesn't have a voltmeter for the alternator and the coolant gauge works but just shows either hot or cold.
Is there a better way to utilize the other two spots in the gauge that would help me on my hypermiling journey? |
On my scangauge I pretty much always use:
Engine load Coolant temp Instant MPG Average MPG Engine load (LOD) tells me how fast to accelerate, and helps tell me when to coat or EOC. Coolant temperature tells me when I can turn on heat, and when I'm installing a grill bock if I've gone too far. Instant MPG is actually not real useful unless I'm being a bit more lazy and don't feel like doing as much P&G. Average MPG I use to gauge how well I'm doing on a trip. The daily commute I know about where I should be at several points in the trip and I can gauge my driving. |
On my ScanGauge E I have a tab for Voltage and Open/Closed Loop, but I don't use it often. Both LOD and LP can be useful for reminding you to get your foot out of it. :)
Mostly I watch Coolant Temp, Average MPG, and Instantaneous MPG. (I would watch intake temperature as well if my '96 Outback provided it.) More broadly, I bought my SG more or less as a toy, but it has paid for itself just in scanning codes on cars among my friends and family. I don't exaggerate when I say I love this thing. :) |
I sought out a 1996 because that was the only year Subaru offered the Outback package, bulletproof 2.2L engine, and a 5-speed manual together. The early 2.5L was plagued with headgasket problems and starting in 1997, you couldn't get the Outback with a 2.2L anymore, at least in this country. Too bad, because 135 HP is plenty for some of us! The downside is that the gas mileage isn't stellar. It takes mods and very careful driving to match what other cars get without even trying. I compensate by batching errands and riding my bike for short trips. If I could go back in time and buy a brand-new 1996 EJ22 MT5 Outback when this one finally dies, I totally would. :thumbup: |
~50 MPH on the highway with the engine fully warmed up is the sweet spot for most cars. I see instantaneous MPG in the 30s and 40s as well in those conditions, as long as I'm not facing a big headwind. Of course, I also see instantaneous MPGs in the hundreds when coasting down a hill, so it's important not to get too excited about momentary figures. ;) |
I'll report back on Wednesday with my tank findings. I'm hoping for somewhere in the 30's. |
Good luck! :thumbup: |
I just bought a second ScanGauge, You can "daisy chain" them together and then monitor 8 functions. just use a standard Ethernet cable and plug it into the open port on each unit.
I monitor inlet air temp coolant temp instantaneous mpg tps long term fuel trim short term fuel trim lod battery voltage |
What is the LOD? When I turned the gauge to it, there was no numbers or anything. Just LOD.
it is possible that Subaru do not transmit this parameter? You would have to call ScanGuage to be sure.
Maybe another Subaru user here can chime in. My Saturn shows the data. But there are other parameters such as fuel pressure that don't show up like yours. |
