05-26-2016, 06:15 PM
New tire question
Looking at new tires for my car.
The tires I'm looking at are these....
Continental*PureContact with EcoPlus Technology
The question I have is, what do you think would be the better option. 205 50r17, which will be a little narrower but also shorter, or 215 55r17, which will be slightly wider, but will lower RPM because it is taller
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
05-26-2016, 07:41 PM
how much time do you spend at 'cruising'?
how much time in stop and go?
taller is better in my opinion
05-26-2016, 09:46 PM
Taller is usually better.
05-26-2016, 09:51 PM
Most of my drive is cruising, on top of plenty of road trips
05-26-2016, 11:49 PM
Cyborg ECU
Then you go taller, for gearing advantage. The extra rotational mass will matter less in cruising than it does in stop/go at lower speeds.
05-27-2016, 11:24 AM
this^^^^^^
05-27-2016, 03:41 PM
Thanks everyone. I ended up going with a different tire all together after reading the reviews. Should still be one designed for better fuel economy, and also 205 55r17. Best of both worlds in my opinion
The Following User Says Thank You to Rango318 For This Useful Post:
