EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Better mpg after filling up? (https://ecomodder.com/forum/showthread.php/better-mpg-after-filling-up-25032.html)
sheepdog 44 02-22-2013 06:10 PM
This is just anecdotal evidence, but for the 3 cars i've owned, it seems that after filling up i instantly get better mpg and power. This effect goes away the next day after the car has settled. It's "feels" like enough of an improvement that i'm probably not imagining it. In my previous cars i noticed better acceleration. With an instant mpg gauge, i can see i'm getting the mpg i would maintaining speed, but while i'm slowly accelerating.
Has anyone else noticed this?
Could it be vapor in the gas tank? Fresh fuel? New fuel in a warm engine?
Flakbadger 02-22-2013 06:12 PM
I feel like my vehicles have always responded to new gas like you said. I wonder if it's oxygenation, or just in my head...?
pete c 02-22-2013 06:40 PM
It's in your head. Gas has weight. Weight slows your car. End of story.
A full tank may improve handling by improving weight distribution, but that is about it.
gone-ot 02-22-2013 06:55 PM
Mathematical Delusion - The MPG variations are due to the "Law of Large Numbers."
Initially, right after filling up, the MILES and GALS numbers are both small and little changes are immediately seen on their result, ie: MPG = MILES / GALS
...for example, small initial changes:
MPG = (10/0.3) = 33.3 mpg ...BASELINE, 10 miles & 0.3 gallons.
MPG = (10/0.2) = 50.0 mpg ...-0.1 gal gas
MPG = (10/0.4) = 25.0 mpg ...+0.1 gal gas
MPG = ( 9/0.3) = 30.0 mpg ...-1 mile
MPG = (11/0.3) = 36.7 mpg ...+1 mile
...which are variations of +50%/-25% for gas and ±10% for mileage.
However, as you accumulate mileage, the MILES number becomes large enough to 'swamp' similar changes in the GAL number.
...for example, here are the same changes as above, except at a distance of 150 miles (same ×15 ratio):
MPG = (150/4.5) = 33.3 mpg ...BASELINE, 150 miles & 4.5 gallons.
MPG = (150/4.4) = 34.1 mpg ...-0.1 gal gas
MPG = (150/4.6) = 32.6 mpg ...+0.1 gal gas
MPG = (149/4.5) = 33.1 mpg ...-1 mile
MPG = (151/4.5) = 33.6 mpg ...+1 mile
...which are variations of just ±2% for gas and ±1% for mileage.
Thus, as the mileage and gas input numbers get larger the the resulting variations in the MPG numbers become smaller, even though the changes were identical!
Cobb 02-22-2013 07:37 PM
Yall wrong :D Its the fact you get over spill in the carbon filter and it enriches the air charge into the engine til it evaporates off for a few hundred miles tops. :thumbup:
sheepdog 44 02-22-2013 07:40 PM
I'm talking instant mpg and power just after putting gas in. Which lasts till i park the car and it sits overnight. Normally i do ten miles after a fill before i get home, so i don't know how long it could last. I'm not saying you could improve your mpg for a full tank. But there is definitely something going on with how an engine runs just after putting some gas in.
BHarvey 02-22-2013 08:35 PM
The drive home from filling up is done with a warm engine, then the next day you suffer your first cold start on a new tank and MPG suffers.....
pete c 02-22-2013 09:07 PM
So, what you're saying is the gas gets stale?
Cobb 02-22-2013 11:09 PM
Its because the filter on the hose contains magnets and they help to align the atoms inthe fuel as it enters your tank. Then the charge wears off the next day and your performance is less?
wmjinman 02-23-2013 02:18 AM
I seem to notice the opposite effect - I'll be getting a particular MPG for a tank, and then fill up, all excited to improve upon it (warm engine, etc.), especially on a trip. But the ScanGauge will show much LOWER mileage for the first few miles. Seems like I can get it to start climbing eventually, but not at first.
I do try to top off the tank until it won't hold any more, thinking that's the only way I can be sure it's the same each time. Is this somehow wasting gas (burning extra out of the carben cannister & running rich, or something).?
? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? :confused:
BHarvey 02-23-2013 09:32 AM
Your short trip mileage will be hard to beat compared to your tank mileage in the first few miles because you have only been running a few minutes on the tank, vs many hours. I have run over 20 hours on a tank (1200 minutes).
pete c 02-23-2013 10:18 AM
That's why the magnets on the filler hose is a bunch of snake oil. Anyone with half a brain knows you need to put the magnet on the fuel line as close to the injectors as possible.
Cobb 02-23-2013 10:44 AM
Well, the good fuel economy effect was discovered on insightcentral that you over filled the tank spilling fuel into the characoal canister and it helped to enrich the mixture of air into the engine, so it used less fuel from the injectors and the system read higher than normal mpg.
When my father bought gas for me I always over filled my car and never notice any of this. I just like to tease my former co workers that I can go 175 miles before the needle moves off the full mark. :eek:
sendler 02-23-2013 04:00 PM
I have noticed this too. The first few miles after filling up show much better fuel economy on my Insight's freshly reset running average. It's not just numbers. The car feels that it is doing more with less throttle. I suppose it could be from a vapor rich charcoal can.
wmjinman 02-23-2013 05:04 PM
Wow, that's weird. Now I'm really curious as to why I'm seeing the opposite.
Or maybe it's just the old deal of where people tend to remember the bad events more than the good ones. ? ? ? ? ? ? ?
But if I got 45 at fillup, and then take off from the gas station, and in the first 20 or 30 miles of highway driving, look at the ScanGauge hoping to see better than 45, it seems like it's 39 instead. (!!!) And I'm thinking, "Gee, and this was all "highway" driving so far, too". (except for the initial acceleration from the gas station)
RedDevil 02-23-2013 05:08 PM
That would mean that the discrepancy between the FE from the MID and the fuel pump/mileage ratio would be larger if you max the fill than if you don't.
Sounds reasonable enough though, and we know there is a spillage recovery system. My guess is that the gas contains some very light components that evaporate over time and get sucked up by the recovery system, enriching the mixture while evading the MID's equasion. After a day the lightest gases are gone and so is this effect.
My home had a pair of magnets on the main waterline when I bought it, so the H2O molecules got aligned to give better fpg from the loo (just guessing here). Sadly, as my brain has 2 halves, I felt like removing them so my loo now no longer has any boasting rights.
sendler 02-23-2013 05:09 PM
The high economy effect only seems to last for a few miles.
wmjinman 02-23-2013 05:13 PM
Originally Posted by RedDevil (Post 357947)
My home had a pair of magnets on the main waterline, so the H2O molecules got aligned to give better fpg from the loo (just guessing here). Sadly, as my brain has 2 halves, I felt like removing them so my loo now no longer has any boasting rights.
LOL!!! :rolleyes:
jamesqf 02-24-2013 12:30 PM
I see this effect quite often, but do you suppose it might have something to do with the fact that when I leave the couple of places I most often get gas, I'm going downhill for quite a ways?
