EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   which is better route--short/slow or long/fast? (https://ecomodder.com/forum/showthread.php/better-route-short-slow-long-fast-11819.html)
carolyn2 01-11-2010 09:39 AM
Had to go to a mall yesterday. Google maps gave two different possible routes--one was mostly via major highways, total 19 miles distance, takes ~30 minutes estimated driving time. The other was across towns, smaller roads, total 11.5 miles distance, takes ~30 minutes driving time.
Which route would use the least fuel if driving "normally" (since I didn't see all your hyper mile hints until today)? If driven hypermiling style? Does it matter what car/mpg etc one is driving? We're driving a manual transmission Toyota Matrix, mid-powered version (sorry forget which model that is).
I've tried to do a little research to figure this out but really couldn't get very far--are all cars really so much less efficient at lower speeds? How much gas is burned at idle?
If this is a common question, just point me to the previous thread, and thanks so much for your help!
carolyn2 01-11-2010 09:44 AM
Forgot to add, sorry if this is in the wrong forum, I'm a newbie and this was my best guess.
dcb 01-11-2010 09:57 AM
generally short and slow are both good formulas for saving gas. Of course it depends on course, driver, technique, vehicle.
Assuming a small stick shift, and patient technique I would take the shorter city route.
Daox 01-11-2010 10:06 AM
I can say with confidence that the shorter trip will take less fuel to get there for both a ecodriver and normal driver.
19 miles @ 28 mpg (the highway epa rating for the 2.4l engine) means .68 gallons used.
11.5 miles @ 21 mpg (the city epa rating for the 2.4l engine) means .54 galons used.
Now, if you are an ecodriver and use some of our techniques, you can EASILY beat 29 mpg in city driving. So, all roads lead to short and slow. :)
BTW, welcome to the site. The Matrix is a great car, I just replaced mine this summer. :)
Frank Lee 01-11-2010 01:59 PM
Homer asked Marge on Whacking Day (Snakes! What did you think?) if he should do it slow, or fast. Marge said do it slow, then fast! ;)
tasdrouille 01-11-2010 03:18 PM
Do you have instrumentation? If so try both and see for yourself. But as others have said, the shorter route often is your best bet.
carolyn2 01-11-2010 03:54 PM
No instrumentation--didn't even know it existed (outside of Priusii -pl?) until today. Now it's on my wish list. We've mostly tried to improve mpg by decreasing miles driven.
Doing the math, as suggested above but with my averages, I get
short: 11.5 miles at 27mpg city = .43 gal
long: 19 miles at 36mpg highway = .52 gal
so it does look like shorter is better. But I'm still wondering at the equal driving time aspect and wondering if that needs to be accounted for. What rate of travel does city mpg assume, I wonder?
Thanks for everyones thoughts. And yes, we think the Matrix is a great car, though I don't like the styling of the newest model.
luvit 01-11-2010 07:33 PM
first thought: fewest dead stops.
Mustang Dave 01-12-2010 09:59 PM
My short/slow route to work nets about the same MPG (and travel time) as the longer/faster route. Overall, less fuel is consumed on the short/slow route.
Good point. My shortest commute route to work has more stop LIGHTS, but less stop SIGNS than the longer routes. If you time the stoplights right, you never have to get 0MPG. :) YMMV.
wagonman76 01-15-2010 11:58 PM
I can take two different ways to work. The first way is 26.6 miles and is a little hilly but nothing outrageous, and goes through 3 towns. The second way is 25.6 miles with extreme hills and gets me 2-4 mpg less. So the first way is better for overall fuel use, but the first way also contains 15 miles of one of the most beat up roads in the county, plus the whole road is a major deer crossing. But if it's icy, the hills and blind intersections on the second route make for a lot of accidents and the speed bumps on the highway tear up the car too. So it's a toss up pretty much.
ai4kk 02-02-2010 04:46 PM
This is how I travel...shortest route from city/Point of Interest to city/POI. Nice compromise between the absolute fastest and the most scenic with the shorter distance usually making up a little for the slower speeds. Of course, my mileage is usually a lot better too and I see areas that mos outsiders never even hear of.
For example, I bought my truck in Richmond, VA then took backroads to Roanoke (through Appomattox), then to Asheville and Atlanta....I think we spent maybe an hour total on the interstate.
SentraSE-R 02-02-2010 06:59 PM
What the others say. Shorter and slower = win-win. Win for the regular driver, and a bigger win for the hypermiler. Serious hypermilers can get better mileage in the city than they can on the highway.
Mustang Dave 02-02-2010 08:54 PM
I generally average better mileage commuting than on road trips.
Lazarus 02-02-2010 09:04 PM
It would be impossible to tell without a SG (Scan Gauge) but I'll go against the grain and say the longer trip provided there are more stops on the shorter one. If you can travel at around 40-45 MPH with no stops I think you could do better then stop and go from a cold start congested driving. Although 8 miles is a lot to make up.
