04-10-2015, 01:08 PM
Rotating wheels effect on aero (CFD picture)
I was reading an article about aerodynamics this morning and stumbled upon this picture. I thought it was interesting enough to post it up.
Blue is low air speed, red is high air speed.
The Following 7 Users Say Thank You to Daox For This Useful Post:
04-10-2015, 01:34 PM
Looks like most of the wake width is coming from the front wheels. Am I seeing that right?
Thinking of "velocity varies inversely with pressure" makes this image more meaningful to me.
This is the view from below, correct?
04-10-2015, 02:14 PM
Ultimate Fail
Do we know the vehicle that was tested ? It would be interesting to see the wheel design / wheel well clearances.
04-10-2015, 03:09 PM
This is a bottom view, and a lot of the wake is coming from the wheels. Farther up on the body, this probably isn't true, but we are looking from the bottom.
Nope, I provided all the data they did in the article.
04-10-2015, 04:38 PM
Whatever it is is weird. The wheel (+ tire?) diameter is 1/5th the vehicle width. If the 'saloon' is six feet wide, it must be running 14" rims with no tires.
The wake from the rear tires appears to be almost as great. Probably down to the differing height of the wheelwell arch.
04-10-2015, 09:07 PM
...The wheel (+ tire?) diameter is 1/5th the vehicle width. If the 'saloon' is six feet wide, it must be running 14" rims with no tires...
I think the gray circles are tire contact patches, about 14" diameter by your math, which is about right I'd think
The Following User Says Thank You to mwilliamshs For This Useful Post:
04-14-2015, 03:32 PM
from below?
The CFD is representing the road as a pane of glass,and we're seeing the velocity distribution at the road surface only,right at the contact patch.
The front tires are creating part of the bow wake and the rear tires are embedded within their turbulence.
Luminescent soap smears will reveal the same pattern on the floor of a wind tunnel and with a telephoto lens,you'll see the same thing on a dusty road.
