Bionic Van
I'm sure everyone on this forum has heard of the Mercedes "Bionic car" based on the boxfish... I'm wondering if I could apply any of its principles to modding my 15 passenger van, as suggested here:
Fuel Efficient Vehicles Now! - Bionic Vans Trucks & Buses Or maybe something like this: AeroTruck 1 The boxfish car claims a Cd of .19. I know the enormous area of a passenger van would blunt the effects of a slippery shape, but I figure anything's worth a shot. Can anyone enlighten me as to why the Mercedes's shape is so much more efficient than a normal van's? Could I work some kind of cloroplast wizardry to emulate it on my own vehicle? Thanks! |
Well, the overall shape is quite a bit more aerodynamic than a conventional van. You could definitly work on rear wheel skirts and an under belly pan.
van
Conventional vans are for hauling,and are optimized for useful interior volume.So you get a lot of floor area you can stack stuff,right up to the ceiling.Its a cubist's dream come true! The down side,is that vans tend to be slab-sided,with very little plan- curvature ( curvature to the sides when viewed from above),and a relatively flat roofline.--------------------------------------------- This means that the van is basically a "full wake" vehicle.The cross-sectional area of the van,from the windshield back,is constant,at full projected frontal area,until the very back of the van.This means that the wake of the van is also the size of the full cross-sectional area of the van.Really big!!!!!!!!!!!!!!!!!!!!!!!!! ------------------------------ With the "bionic" car,you'll notice that the roofline curves gently down as it projects towards the rear of the car.Also,if you were above the car,looking down,you'd see also,that it was growing ever so slightly more narrow from front to back.This is where the Cd0.19 comes from.--------------------------------------- For your van,the air is disturbed from it's "rest" position,knocked out of place and accelerated to about 1.3-times the velocity of your speedometer,and since there is no narrowing of the body,the air stays completely out of equilibrium,until the van passes,where it tumbles into the void left behind the van,creating an enormous wake of turbulent air which cannot convert itself from its state of kinetic energy,to the calm,atmospheric pressure air it was before you came along.This in essense is your aerodynamic drag.--------------------------------------- And for your van there is no easy remedy,as the only way to get the air re-organized without turbulence,requires a lengthy tail.You could do all the mods you see for the Fed Ex concept truck.This would reduce the forebody drag,when combined with a full bellypan.You might see Cd 0.20.------------------------------------------- If your at say, Cd 0.38 now,and you could cut drag to 0.20,that's a 48% drag reduction,and would be good for about 24% better mpg at 55-mph,a little better at 70-mph,I don't think you could do better unless you cut into the roof and sides,and re- designed the rear 1/3rd of the vehicle.All your time trouble and material expense would have to be recouped in fuel savings.And you'd be losing interior space.--------------------------------------- A boat-tail will give you some savings,but the extra length can be a real issue when parking.-------------------------- you may want to do a ecomodder search for aero-mods # 11(aftbody streamlining/boat tails),there is some empirical data for you to peruse and may be of benefit to you.
Thanks, Aerohead, your explanation was really helpful. So I guess the best thing to do is to try to go from "rough brick" to "smooth brick" with a belly pan, wheel skirts, etc. I might also try something like this for long hauls where parallel parking isn't an issue:
Green Car Congress: New Boat Tail Design Could Improve Class 8 Truck Fuel Economy by 10% I don't think I'm ready to invest in the ultimate solution: AeroTruck E-38096: Air flow testing on aerodynamic truck |
I think the comparison between the van and the Bionic "Boxfish" car is reaching.
Aero truck
Whoa, that's encouraging! Since the thing's already as big as a whale, an extra 18 inches isn't terrible... Maybe I can make it so it folds flat against the sides of the van when not in use.
That's the trick.And the jury is still out,with respect to the "best" solution.I did a fan-powered inflated tail also and it worked well.It was a crude proof of concept and I'll probably re-visit that one.If you look carefully at the NASA link photo,you'll notice that the tail starts out with very little curvature.The further it goes,the steeper it gets,to a point where it follows basically a constant angle from there back.If you start too steep,the flow will separate,with little benefit to your wallet.Scale that photo to your van,and you ought to be good to go!
I don't think the World is ready for Luigi Colani.I think the atmosphere is though.
What... the... hell... is... that?
Wait 'til you see how he dresses!
truck in the 2nd pic on the right looks somewhat more decent on the aero... very cool designs in any case.
Colani took a bunch of his creations to Bonneville including the 18-wheeler.It was quite the candy store! Some designs were more flambuoyant than others.I don't remember what the truck scored,but I remember the Cd was quite good.And as Marie Antoinette has said"We've already forgotten more than we'll ever learn."
What's interesting in the very limited size of the grill compared to what you usually see on the road, especially here in the US.
grill
Unfortunately, of all the people in this world who are not ready for this fellow, long-haul truckers are probably the least ready...
ready
My apologies to truckers... I guess the only information I have about them is from "Smokey and the Bandit," which probably isn't a reliable source.
Good point about the economics, though. You would think that companies such as Wal-Mart, for whom cheap transportation is a real cornerstone, would be really interested in this sort of thing. Pretty soon transportation costs are going to affect their business model, and their board members won't really care if the trucks are a bit outlandish looking. |
My family's bread and butter is trucking. My father owns a company, two uncles drive trucks, my brother and two cousins are mechanics.
Yes, it is fair to say that many truckers are big-block lovin, manly men. However, i think the reason for lack of change is financially driven as you'd expect the reasons FOR change to be. With a sudden up-shot in deisel prices, many companies are struggling in this industry. You can't just change your fleet over to more efficient trucks. A new "typical" truck is like a hudred grand. Some technologically advanced engineering spectacular would cost much more. That buys a lot of gas and uses a lot of money that these companies just don't have right now. |
Very true. My fiance's family has a trucking company and the pickins are slim. The best you could do now for a more aero truck is hope you know someone with some scrap sheet metal and a welder to test with.
And yeah, they're manly men who love their Harlies, red meat, and mass produced beer-like products. They're also not the brightest, but they're family so it's ok ;-) You figure out how to quickly and cheaply retro-fit existing trucks to reduce fuel costs by even 5% and you'll have yourself "the better mousetrap" for which people will beat a path to your door. |
economics/big government
I think it would be VERY difficult to mass produce a truck or trailer who's additional cost due to engineering offset fuel cost by enough to make people's heads turn. The construction of a brick-like trailer is just so simple compared to something more aero. That simplicity likely also makes it less weight and more durable/repairable. Every time I'm in dad's shop there is a trailer there with a bent bumper or scrapes down the sides, or a gash in the roof. If it was made of some wavey-shaped fiberglass it would be more expensive to repair.
cost
You mistake science and engineering. Yes, the science of it is well-known in the aero field. You need an engineering firm to make the drawings and test the concepts. Sounds simple, but it ain't (I figure you know that much!)
So how does a kam-back truck hold the same amount of freight as a box-shaped truck? make it 10 feet longer? that is out because if htey could make it 10 feet longer, it would be square, and hold 8 more skids to make more money than the kamback could recoup in fuel. Okay, make it some sort of accordian fold-up deally that you deploy for hte highway. Now you're talking about a 15-thousand dollar piece of heavy equipment if you want it to last for 20 years problem free. What if it breaks? Does your in-house trailer repair dude know anything about fixing it? Nope, send it to a specialty repair shop for 5 grand. And what does a heavy piece of equipment like that weigh? factor that into the fuel equation, and MUCH more importantly, tell the trucking company that their maximum load has just been reduced by that much. Much much much much more to the puzzle than simply "toss on a kam-back and a nose cone". Everything in that industry is SIMPLE and STRONG. Those are the prime requisits. |
science/engineering
Throw in the flotation tires.If I were the government,I'd have the national labs develop no-cost technology for "convoy" driving,allowing truckers to NASCAR draft,bumper-to-bumper in trains ,say,up to 10-rigs long,dedicate lanes for them to do it in,and imprison any motorists in cars which endanger the truckers,driving coast-to-coast,saving up to 15% in the draft. |
Okay, I definately need to go and look up that specific trailer idea. That sounds good.
Now... freeway drafting technology, THAT is something that truckers could accept! You'd need ONE patented technology (preferably a standard, not a product) that was cost effective so you get massive market saturation as quickly as possible. You would need equipment attached to trailers AND trucks and control systems to manage speed and more importantly inter-vehicle communication. When the first guy in line slams his brakes, ALL the trucks need to slow down at an equal rate. Considering load differences, you'd probably be able to get by with at least a 10-foot following distance, which would be spectacular for fuel savings. If one guy is too heavy, the others around him would have to immediately compensate to give him cushion. When I drive my cube van (see my thread for horrible FE details), it is WONDERFUL when I can get into a convoy; I lift my foot up about an inch and a half and maintain the same speed. When that convoy is 2-lanes wide it is even better. |
Is this it?
Most of the info I found when searching for Freuhauf was about current designs, them losing business, and recalls. |
Nope,that's not it.Let me look at the other posts,see where we are,and I'll jump in.
is this it?
