EcoModder.com
-   -   Block heater on a 2006 matrix (https://ecomodder.com/forum/showthread.php/block-heater-2006-matrix-15941.html)
Weather Spotter 01-28-2011 09:18 PM
Well after stalling a few cold winters I decided to splurge on a mod with little payback but some comfort gain.
I bought a block heater from:
the kit is the same as others have used:
http://www.trdparts4u.com/scripts/pr...dproduct=-5127
I looked to see what wattage it is and mine was stamped on the end 400 watts:
http://i835.photobucket.com/albums/z...ts/file-76.jpg
My next task was to find the hole for it. Other threads pointed me in the right way so my fingers went exploring.
engine bay
http://i835.photobucket.com/albums/z...ts/file-82.jpg
air box/ oil add area
http://i835.photobucket.com/albums/z...ts/file-81.jpg
Now look down and find the side/ back corner. It is on the side facing the battery and slides in the direction of the washer fluid tank.
These pics are with it slid in half way so you can see the end:
http://i835.photobucket.com/albums/z...ts/file-78.jpg
Here you can see the end with the prongs.
http://i835.photobucket.com/albums/z...ts/file-79.jpg
http://i835.photobucket.com/albums/z...ts/file-80.jpg
Where I ran the plug:
http://i835.photobucket.com/albums/z...ts/file-83.jpg
After 10 min of being plunged in I almost burned my hand trying to see if it was warm. It is!
Tango Charlie 01-28-2011 11:15 PM
Oh, you're gonna like it! Can't beat instant heat this time of year.
Is that the 1ZZ-FE engine?
gone-ot 01-29-2011 12:16 AM
...the pictures look just like my wife's '04 Vibe base with the 1.8L (1ZZ-FE) engine.
...I'm thinking about getting one for my '09 Vibe if I can find one.
KITT222 01-29-2011 12:38 AM
My engine block heater won't work. I'll plug it in when I park at night (just to get it to work, timer comes later) and int he morning it's still cold! :mad: Tomorrow my dad and I will trouble shoot it. I ran the cord up through my engine bay, and the cord wraps by my battery. Just a hold until we get something like Doax did to his Matrix a while back. Not the plug in the body, but in the grill block or something.
The Vibe/Matrix has the 1ZZ-FE VVT-I engine. Only the GT or XRS has the 2ZZ-FE VVTL-I.
Weather Spotter 01-29-2011 05:53 AM
Yes it is the 1zzfe engine. If I read the site right this heater works in most Toyota small.blocks. check it out but it just might work for you.
The set up is simple enought that if it does not heat up I say you have a bad heater.
Weather Spotter 01-29-2011 03:57 PM
Well my car this morning was showing a Water temp of 86F with an ambient of 24F. That is a 62F increase. I also saw that number jump up rapidly to 110F then slower to full temp. I bet the first coolant that circulated by the warm area made that number jump. So not bad. Full temp was at the 3 mile mark instead of 5.
But my MPG for the trip was lower then normal. This was due to 4-5" of the white stuff that we get this time of year. I lost 1.5 MPG of my 240 mile tank average :( 6 hours of overtime made up for it :)
KITT222 01-29-2011 07:03 PM
Uhhh, yeah, scratch that. I was looking at the coolant temp, since I don't have engine temp. Just figured that out today...
postmac 04-01-2011 03:36 PM
mpg improvements
Care to guess your mpg improvement using the engine block heater?
Weather Spotter 04-01-2011 05:09 PM
Not sure, I know it speeds up my warm up times by about 20-30% (depending on how cold it is out) but I have to admitt the rational for it was more user comfort then MPG.
Weather Spotter 08-19-2012 05:22 PM
I added a port on my nose cone for the heater:
http://i835.photobucket.com/albums/z.../file-1830.jpg
