EcoModder.com
-   -   Block heater questions (https://ecomodder.com/forum/showthread.php/block-heater-questions-27722.html)
sully06 12-09-2013 11:18 PM
I've done some googling but I'm still unsure as I've never had a car with a block heater nor have I ever installed one. Now I have a 99 Camry 4 cylinder so I'm guessing my options are few. I found this on ebay is it good? Any have experience at installing one like this do I have other options? Any help would be appreciated. Thanks btw I'm in Mississippi so it doesn't get too terribly cold
Zerostart 3100049 Freeze Plug Type Engine Block Heater 4 Cylinder Only | eBay
HyperMileQC 12-10-2013 12:30 AM
These block heater are usually not so hard to install but it depends on the car. You should have the best results with this type of heater.
There are other options : heater pads for oil pan and transmission for example.
sully06 12-10-2013 12:52 AM
Thanks yeah there is a clear view to the freeze plug. I'll have to check those out.
sully06 12-10-2013 01:10 AM
So like this? Anyone use these with good results?
New 200 Watt 12 Volt Silicone Pad Oil Filter Heater Gasoline or Diesel Engines | eBay
slownugly 12-10-2013 07:25 AM
The most bang for the buck would be the freeze out plug type heater.
What the lowest temps you encounter down there?
sully06 12-10-2013 09:46 AM
Sometimes it gets in the teens but I would say 30ish normally which brings me to my next question how strong of one do I need? Thanks
oil pan 4 12-10-2013 10:10 AM
I did some reading on the subject:
http://ecomodder.com/forum/showthrea...ing-25512.html
slownugly 12-10-2013 10:19 AM
I use 400w but it wouldn't hurt to go a little more. Like oil pans link says 600w would be pretty good for a 4 cylinder but 400 is enough for me. I shoot for a minimum plug in time of 1 hour but a good goal is about 2 hours.
echo-francis 12-10-2013 10:48 AM
the more watts it has the better it is :)
if your are good at DIY you can try this
http://www.amazon.com/Kats-13150-Alu...s=block+heater
