EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Blocked my lower grille today (https://ecomodder.com/forum/showthread.php/blocked-my-lower-grille-today-10920.html)
Magister 11-08-2009 07:14 PM
1 Attachment(s)
on my Elantra HD, with a piece of black foamboard and 6 black tie-wraps.
I put it behind the grille so it's almost invisible, the coolant temp is almost the same, about 87°C and it's about 15°C outside today, so in winter at -20°C I think it will help to keep my engine warm. :thumbup:
k.civic.f4i 11-09-2009 12:14 AM
nice. if you can, try to make one thats flush with the bumper
RobertSmalls 11-09-2009 05:12 PM
Yes, it would be a little more aerodynamic to have a smooth bumper, but what you have now is a stealth aeromod that doesn't impact the appearance of the car at all. Nice work. I bet you can leave it installed year round.
Magister 11-10-2009 09:13 AM
A member here already did it
http://ecomodder.com/forum/showthrea...html#post15899
But I don't like the look, and I'm not sure it makes a difference, once the air is compressed in the hole, the coming air just slide on it I think, it should be simulated on a computer!
