EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   BMW i3 - Low Hanging Fruit (https://ecomodder.com/forum/showthread.php/bmw-i3-low-hanging-fruit-37645.html)
Snax 07-09-2019 02:02 PM
I recently watched a video where it was mentioned that the cd for the i3 is rather high at 0.30. Looking for some low hanging fruit to improve upon that.
Obviously the mirrors are an easy target. One owner has already done a delete and camera retrofit to that end and it is probably going to be my first step.
I may go so far as to put fairings over the rear wheel openings as well.
That said, a boat tail per-se is out. The car already looks funky enough as it is.
Got any other suggestions likely to produce a measurable result?
https://www.youtube.com/watch?v=UvZrizh4Q4E
redpoint5 07-09-2019 03:12 PM
Sounds like you've already done your homework and decided what you're willing to mod. I'd simply drive slower if the ability to make a trip were in question. If the ability to make a trip is often in question, I'd get an EV with more range.
How does the undercarriage look?
NeilBlanchard 07-09-2019 03:15 PM
Frontal area is totally independent from the Cd, and vise versa. Cd is the overall shape, and that can be scaled up or down in size, and the Cd would remain the same.
Snax 07-09-2019 05:02 PM
Good catch. Edited my OP.
Snax 07-09-2019 05:03 PM
It's not horrible. The front subframe area seems like the opportunity for greatest improvement however.
https://www.bmwblog.com/2014/11/11/l...i3-underneath/
California98Civic 07-09-2019 05:08 PM
Can it be lowered? Doing so, even one inch, will somewhat lower your effective frontal area and thus your CdA, total drag area (the mirror delete does that too). But the rear wheel cover is your lowest hanging fruit, I would bet.
Snax 07-09-2019 05:27 PM
I have installed springs that drop the front 1" and rear 0.8", giving a touch more rake as well. I am currently examining possibilities for going lower, but that is already pretty limiting on travel and ride quality already. Thinking about the potential to make that dynamic however with air suspension.
redpoint5 07-09-2019 05:33 PM
My money would be on mirror delete, but what do I know. Rear wheel covers could be it.
Tahoe_Hybrid 07-09-2019 06:30 PM
Originally Posted by Snax (Post 601663)
I recently watched a video where it was mentioned that the cD for the i3 is rather high at 0.32 if I recall correctly. Looking for some low hanging fruit to improve upon that.
That said, a boat tail per se is out. The car already looks funky enough as it is.
aero civic front end swap :rolleyes:
Snax 07-09-2019 07:05 PM
Ha ha, yeah . . no . .
I was just looking under the rear area ahead of the bumper, and it looks like they did wrap everything up like a diffuser, but it lacks side dams. I might try hot gluing something on down there to test out as that seems like one of those things they would likely have compromised out of the design for durability considerations.
All else on the car is otherwise so clean that substantial gains seem most likely to be with either my driving or the boat-tail I am so against.
Anyway, unless people have other suggestions, I will probably stick to this thread for whatever mods and testing I do.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
