Boat tail - Redneck style...
Well, I couldn't stand it anymore. After seeing the results of the other boat tailed vehicles here on the site, I decided it was time to jump in the pool and join the party...:)
It may not be as pretty as Metro's or Three Wheeler's or any of the others here that have ventured in this direction. It does however, do the job... The building technique and materials used are similar to others here. Yet, slightly different. So, I thought I'd show how to do it, Redneck style...:D The first thing that needs to be done is to establish the center line of the vehicle. In this case, I used the front and rear factory license plate bolt holes then measured and marked the center. (Caution, this may or not be the actual center line) Next I found a flat surface to work on. Using a plumb bob, I transferred the center line of the vehicle to the surface. Then snapped a chalk line between the marks and past the rear of the vehicle several feet. With the chalk line extended it is then possible to locate the center of the rear of the boat tail with the plumb bob. (important) I decided to use 1/2" EMT for the frame work as it is relatively inexpensive at about $2 a 10' stick, weighs 2.2 lbs. and is easy to bend and weld. It's strength also adds significantly to the structural integrity of the tail. In mocking it up, a step ladder, saw horses, boxes and duct tape were used to help hold the lengths of conduit. (sorry no pictures) :o I read somewhere on here that 50% of the template would give me 90% of the result I was looking for. (Template found here http://ecomodder.com/forum/showthrea...ion-21952.html) So, after a little trial and error, this is what I came up with. It added about 4' to the total length of the car. http://i536.photobucket.com/albums/f...ps4244bf14.jpg Where the conduit is attached to the car, it is hammered flat on on side. Where the conduit is welded, it is first slightly flattened on both sides. A conduit bender was used for the 90 degree bends. http://i536.photobucket.com/albums/f...psed0675db.jpg The curvature of the top of the boat tail was achieved by jamming a piece of conduit between the upper and lower conduit with the bottom and back being supported. Allowing the top conduit to flex. Then, I just kept taking pictures and adjusting until it fit the template. Once I was satisfied, it was tack welded in place. Then it was removed from the car and fully welded. (additional cross bracing was added to stiffen the cage, not shown in these pics) Self drilling screws were used to connect the frame to the car initially, then 1/4" bolts after. Electrical. I will be using truck-trailer flush mount tail lights. I disconnected the plugs to the OEM tail lights and used those piggy back snap connectors to attach the new longer wires. Then coiled them up for later. (since the original plugs are still connected, it can be reversed easily if needed) Rear panel. I decided to use plastic corrugated cardboard from Home Depot. It is tough stuff, yet lightweight and $11 per sheet. The rear panel was traced out and cut with snips. It will be installed later Covering the frame. I had a little kammback made from 1/2" foam insulation board that I had installed on the car previously. It held up very well. (8 months) So I thought I'd use foam again. It's ability to conform to complex curves and smooth out transitions is excellent. It is also very light, weighs less than 1lb. and is $10 per sheet. It has aluminum foil attached to one side which would allow it to resist the resins used in fiberglass or a carbon fiber if a more permanent cover is added later. Starting on the side near the top, a extra set of hands and duct tape were used to help hold the sheet in place as it was trimmed to fit the shape of the back of the car and bent around the frame. Once the shape was done, it was then removed and transferred to the foam sheet for the other side and cut. Making a mirror image. http://i536.photobucket.com/albums/f...ps8117f526.jpg Attaching it to the frame was a little tricky. Through trial and error, zip ties were eventually decided upon and used with duct tape on the outside underneath the ties to help keep them from pulling through. The foam when bent, becomes very ridged. ;) Extra material was left around the window opening and taped down. http://i536.photobucket.com/albums/f...psb52dac38.jpg http://i536.photobucket.com/albums/f...ps34473d96.jpg Window. I wanted to be able to see out the back. So I bought a 3x5' sheet of .080 thick acrylic glass for $45. The opening was measured and the material cut. It was then pre drilled before using self piercing screws to hold it down. The extra foam material will be removed later with a razor blade as it was easier to screw down with it in place and made the transition look better. http://i536.photobucket.com/albums/f...ps7dccaaf5.jpg http://i536.photobucket.com/albums/f...ps30183376.jpg http://i536.photobucket.com/albums/f...psa73cfda5.jpg Bottom. The car was put on a lift and fitted for the missing triangle of foam and aluminum flashing around the exhaust. Before securing the panel in place the "extra foam" around the edges of the window were trimmed. The panel was then secured with screws, zip ties and tape. http://i536.photobucket.com/albums/f...pse8c41da3.jpg Here are some pics that show how nicely the foam follows the curves of the car and cage. http://i536.photobucket.com/albums/f...psb58b0fb1.jpg http://i536.photobucket.com/albums/f...psffad3810.jpg Here's a side shot at this stage of compleation. http://i536.photobucket.com/albums/f...ps280c1ed5.jpg Electrical again. Lay out and cut holes for lights. Then wire and install panel with self piercing screws. Cost of lights and reflectors were approx. $45. http://i536.photobucket.com/albums/f...psdc24a35e.jpg http://i536.photobucket.com/albums/f...ps6bb20070.jpg http://i536.photobucket.com/albums/f...ps7b66ee7a.jpg The third brake light is still in the original rear window location and is functional . It produces a dramatic effect without very much glare in the rear view mirror. When I get a chance, I'll post a pic. *update* http://i536.photobucket.com/albums/f...ps6c445aca.jpg Next, tape seams and paint. Done... http://i536.photobucket.com/albums/f...ps9e1863b9.jpg http://i536.photobucket.com/albums/f...ps38983b4e.jpg All in all, it cost a little less than $150 and weighed a little less than 30 lbs. I removed the rear seat 27 lbs. since I never use it. Net gain = 3 lbs. This was a rushed build. I only had 3 days to complete it (ended up taking 4) before I was scheduled to leave on a trip. (taking this car) So, what's it like driving it...??? All I can say is wow...!!! It was apparent immediately that this mod was worth the trouble. I went for a quick 2 mile shake down run. (remember, I was already a day late leaving. I didn't have time for "proper" testing) :eek: The MPGuino was reading higher than when the car is fully warm in the middle of summer. When I turned on to the road near my home, I accelerated to my target speed of 35mph. Then at a certain point of the road, I EOC to my drive way. Normally, I reach my drive way with just enough speed to make it comfortably to it's parking spot. Not this time... When I reached the 90 degree turn before my drive, it was still going 25mph. I had to brake firmly or end up in the ditch...!!! This mod is starting to looking like a winner. So, I pack my things, kiss the dog, kick the wife and off I go, Charleston S.C. to Niagara Falls N.Y. for a fishing trip. Last year the same trip was made in the beginning of September, stats were as follows. 876.12 miles ÷ 14.17 gal. gas = 61.83 mpg. This year stats. 866.45 miles ÷ 12.22 gal. gas = 70.9 mpg Return trip last year stats. (made a detour to Cabala's in W.V.) 937.4 miles ÷ 14.7 gal. gas = 63.76 mpg Return trip this year stats. 866.45 miles ÷ 11.81 gal. gas = 73.36 mpg (866.45 mi. up and back, chances of that happening again 0%) Last year average trip mpg = 62.79 mpg This year boat tail installed = 72.13 mpg A real world increase of 14.87 %. :cool: To say that I am pleased with the results would be a understatement. Now all I have to do is add the rear wheel skirts and a under tray. I'm sure I missed a few things. So, if anybody has any questions, feel free to ask. Well... That's my Redneck boat tail. As Jeff Foxworthy might say... You might be a Redneck, if... "you buy things to fix your car at Home Depot" I guess that would mean me...:) Here are a few pics from out in the wild... http://i536.photobucket.com/albums/f...ps036a302f.jpg http://i536.photobucket.com/albums/f...ps04372bfe.jpg I would also like to thank my friend Bob for lending a hand. > |
That's awesome. Looks like a clean build, too. :)
Brilliant! might be the cleanest build ive seen yet.
Good job done on the cheap, which reduces the time taken to recoup the costs of the mod in fuel savings. So now there are two boattailed cars running around in SC. Expect an occasional pull-over from curious constabulary until all of the local cops are familiar with your car. In addition to your better mpg's, have you noticed an improvement in your high speed performance. A boattail does wonders for your 60 to 80+ mph times on the interstate, the equivalent of a horsepower boost to your engine effective at higher speeds.
Those are some nice gains! Good job man.
You're my new hero!!! That is AWESOME!!! :thumbup:
From one Redneck to the other, that job is way too nice to be a Redneck build. :thumbup::thumbup::thumbup:
regards Mech |
2 Attachment(s)
My apologies, that does not look redneck at all, but very well done!http://ecomodder.com/forum/attachmen...0&d=1369950110http://ecomodder.com/forum/attachmen...1&d=1369952798http://ecomodder.com/forum/attachmen...2&d=1369953292
Looks really good, and it seems to be working really well too!
Do you have any close up pictures of the attachment points on the car? |
Redrodynamics
Thanks Redneck! I kept following further and further into your post and I still can't get the silly expression off my face.
I think the polar ice caps have stopped receding now. Nice project,fabrication,and fabulous results. Too much fun!:thumbup: |
Oh great, how can I top that? :P
Oh right. Pass my classes! :D |
SWEET job, Man!
Have you started getting groups of people asking questions at pit stops yet? |
Oh and for the record... S.C. boys now how to... "Get R Done"...!!! ;) :D < |
However, appreciated. ;) :D > |
Fun, fun, fun!
Welcome to the club boat tail! :) You can check out any time you like, but you can never leave. |
PS: how's your rear vision out that shallow angle plexi?
Thanks...;) :) > |
Uh, is "Nautical Nookie' a slang term for 'boat tail' (wink,wink)?
[Humor intended] |
And taking the time to post that for me...:thumbup: > |
However, it is attached at 8 points. It is really not hard to figure out. ;) > |
It allows you to see traffic quite easily directly behind you. Also... The cross bar across the middle of the window happens to be exactly at the level of most head lights ;). A big plus in my book... > |
Yes it is...:) > |
Very motivating work you've done here Red. I'm looking to do something quite similar for my Festiva with hopefully very similar real world results! :)
Edit: I'm considering rear hatch removal for weight reduction (60ish pounds I think). Any thoughts on that? |
Glad to help! :) |
Nothin redneck about that!:cool: |
redneck=perfection?
Aerocivic has had a hatchectomy under its tail, as has weather spotter's Matrix, if I'm not mistaken. |
I had a few people ask me questions at rest areas along the way. One particular person happened to be a truck driver. Japanese I believe. He took several pictures and said he was very impressed. He told me that he was going to post them on his facebook account as... Quote:
However... What he said next, was the icing on the cake... (Say out loud in a Japanese accent) Quote:
Lol... < |
By leaving the hatch intact, you haven't changed the way the vehicle will respond if involved in a crash. Remember, Big money was spent to pass safety tests in order to keep you safe. ;) Anything less than a full roll cage in lieu of the hatch would be unsafe at best... In my opinion. > |
Are you familiar with the Military theme... thread? You get to be a member of the MPG Militia: http://i1201.photobucket.com/albums/...g?t=1346274961 Being a redneck build I guess black was the color you got when you mixed all your paint together? :thumbup: Here's how Cd started that thread off: http://i1072.photobucket.com/albums/...flyingterd.jpg |
Redneck build, nothing - you nailed it. And picking up nearly 15% when you're already posting 60+mpg, that's huge.
"Kiss the dog, kicked the wife," that was funny right there. Wrong, and I'll probably suffer for laughing at it...but funny. |
Belongs on ecomodder's front page!!
re previous Brilliant.
Now that you have that nice of a tail You really should paint whole car to match. I know most here arent in it for the looks but The MPG gets others to our group and a great looking super economy project will inspire them more still. My kids love the undieing POS project but hate to be picked up from school in it. So I think I will end here on that point.
Bright yellow green or orange suggested solid white if you dont run A/C. |
I would suggest welding in one tube on each side for rigidity but again, this seems to be irrelevant. Quote:
I absolutely understand planning modifications according to ROI, but "aesthetics" seems far more important than economics to most people. I would be willing to pay more and undermine my investment, if it increased the chance of other people following my example, and hopefully figuring out a better way of doing it. |
justme1969 -- What would the kids think if you turned up in something like this? http://i835.photobucket.com/albums/z...s/file-519.jpg |
A very nice project, well done.
Funny you should ask. On the way back I was thinking about the MPG Militia. It would be honor to be a member of the militia. ;) :) > |
