EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Boatloads of megawatts (https://ecomodder.com/forum/showthread.php/boatloads-megawatts-40960.html)
freebeard 06-01-2023 01:51 AM
Just like it's hard to beat the bandwidth of a station wagon full of CD-Rs; maybe moving electicity by ship can have a good ROI in certain situations:
Introducing Battery Tanker X
14,035 views 24 May 2023
The world’s first Battery Tanker X is a 140-meter-long electric propulsion vessel capable of transporting electricity across oceans. Renewable energy can be safely sent across the sea, connecting grids, islands, and offshore wind farms. Marine-grade batteries installed on the ship have a total capacity of 240MWh and are designed and built by PowerX, a Japanese battery startup. This unique ship is planned to be fully certified by international standards, including DNV and Class NK.
Sea-steading here we come.
In other news, I'm a fan of hydroelectricity, from Woody Guthrie's Roll on Columbia to my monthly bill; but it can be done wrong.
$28.3 Billion USD Three Gorges Dam Has Failed | Tofu Dreg Construction Quality |Drought & Flood (2)
alexshock 06-02-2023 11:12 AM
1 Attachment(s)
Last winter, when Ukraine's power infrastructure was bombed by RU, Turkey provided floating power plants, something like this:
https://ecomodder.com/forum/attachme...1&d=1685718727
redpoint5 06-02-2023 12:01 PM
A boatload of batteries sounds like a bad idea to me.
A floating power station should burn hydrocarbons and be quickly refuelable.
Scratch that. A floating power station should decay uranium and only need refueling every decade.
freebeard 06-02-2023 01:46 PM
IIRC Jack Rikard said that a docked aircraft carrier's shore power cable (dock to ship) carried power equivalent to a charging Tesla.
240MWh would [likely] need a chilled superconducting connector.
Maybe obsolete nuclear submarines could have their torpedo tubes turned into electrical sockets?
oil pan 4 06-02-2023 01:59 PM
The problem with batteries is they're heavy. A 2019+ leaf battery has a volume something to the tune of 60 gallons or more but weights over 900lb and only holds the energy you would get out of maybe 5 gallons of diesel if burned for electricity in a piston engine. Then if it's burned in a combined cycle gas turbine steam engine you get double the power out of that much fuel.
That 900lb battery will only let you go 200 miles or so, a diesel fuel tank would weigh half as much and power the car for more like 3,000 miles.
