Old 12-03-2022, 12:29 PM   #1 (permalink)
Dragshield
I came across this while looking to improve my truck's aerodynamics. Can't find anyone that manufactures this commercially. Perhaps he couldn't get it off the ground and get funding to mass-produce them. Has anyone tried this setup? By the looks of the tests he performed it definitely has potential and would be a more practical solution for truck owners that need their bed space VS. an aerocap.
Can't post links yet so google Dragshield
Let me know your thoughts and if anyone has tried such a mod on their truck
2019 Toyota Corolla Hatchback CVT 39.6 MPG avg
moon disk wheel covers
warm air intake
lower grille block
spare tire delete
2016 Ram 1500 Ecodiesel 3.92 gears 24.6 MPG avg
Stage 1 Tune, EPA compliant
Custom 4" DPF back exhaust
Full grille block
Custom full length running boards
The Following User Says Thank You to Pbadgley For This Useful Post:
freebeard (12-03-2022)
Old 12-03-2022, 01:30 PM   #2 (permalink)
Stepped box cavity.
https://www.darcorp.com/projects/pic...th-dragshield/
"We're deeply sorry." -- Pfizer
COcyclist (12-03-2022), Pbadgley (12-03-2022)
Old 12-03-2022, 01:35 PM   #3 (permalink)
Thanks for posting the link
warm air intake
lower grille block
spare tire delete
Full grille block
Old 12-04-2022, 04:06 AM   #4 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Their claims of 14% improvement in mileage seem a bit far fetched but I would not rule out an improvement in drag reduction.
Old 12-05-2022, 10:50 AM   #5 (permalink)
'Dragshield'
It's inventor is our inactive member Brett Herndon ( aka 'Bondo') , a master clay modeler, of Little Rock, Arkansas, creator ( and Patent-holder ) of "Aerolid' and 'AeroTail,' both wind tunnel tested.
I suppose Brett has a means to back up his claim, which may involve caveats, as aerodynamic appliances often do.
The device IS a box-cavity, relieved at the bottom, to allow the tonneau cover to be opened and tilted, without colliding with 'Dragshield.'
In the early 1990s, member AeroStealth fabricated a plywood device, very similar, of which I participated in flow and mpg analysis.
That dog 'll hunt!
freebeard (12-05-2022), Xist (12-28-2022)
Old 12-05-2022, 12:00 PM   #6 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
https://ecomodder.com/blog/ecomodders-gift-ford/
You know whats wild? A guy from Arkansas donated an aerodynamic model to Ford. But no kidding the back end of the most recent Ford GT looks like that model lol
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
aerohead (12-05-2022)
