EcoModder.com
-   -   bolt ons that help/hurt fuel economy? (https://ecomodder.com/forum/showthread.php/bolt-ons-help-hurt-fuel-economy-1703.html)
Chris D. 04-04-2008 03:36 AM
A few things I've been curious about if they would help FE (fuel economy/effeciency)
Header?
freeflow exhaust/catback exhaust?
converting to an electric fan from a mechanical style?
aluminum flywheel?
underdrive pulleys?
I was also curious if I were to upgrade to a high output alternator, would that hurt things any?
I would have sworn I made this post already, maybe i didnt submit it or something? :confused:
Anywho, thanks in advance.. :thumbup:
bhazard 04-04-2008 10:00 AM
Do you know the output of your current alternator?
My tbird has a measly 75 amp alternator stock. I plan to do a "3g swap" sometime in the future, to a 130 amp unit from a 90's Ford.
The shadow has a 90 amp unit stock. It doesn't have nearly the electronics in it the Tbird has, ABS, ride control, that kinda stuff.
I'm gonna say an electric fan would definitely help you. A freer flowing exhaust might too. If you reduce the backpressure too much you will move your power band up a bit in the rpm range. Cure that with a turbo though ;). I don't know about the lighter flywheel and pullies though.
Ryland 04-04-2008 01:43 PM
properly sized headers could help as they have smoother curves, but over sized headers will hurt you, study fluid dynamics and you will understand this better, otherwise if you look at the cars that get great gas mileage they all have smaller exhaust systems then their lower mpg brother of the same displacement engine.
An electric fan is going to be lighter, and only run when the coolant coming out of the radiator is still to hot, but converting mechanical to electrical and back to mechanical is not efficient, so it depends on if you have a big engine that is under load alot, or if you never load up your truck, in other words, if the fan is on nearly all the time then it should be mechanical, if it only comes on when you tow a trailer, or go up a mouton, then it should be electrical.
a lighter weight fly wheel gives you less torque, and makes it harder for your engine to run slower, but if your engine speed varies alot, like driving in the city, or racing where you might shift alot and rev the engine higher, then a light weight fly wheel is perfect.
under drive pulleys are designed for racing, where the engine is turning enough faster that you can afford to turn your alternator slower, they are often aluminum so they are lighter, but they are also smaller, v-belts have a minimum size pulley that they can go around, the larger the pulley they go around the looser the belt can be, and the more efficient the whole setup can be, the belt will also last longer as it's not bending as tightly, so instead of going with a smaller engine pulley, I would go with a larger alternator pulley, that is if your engine is going fast enough to keep the alternator spinning, at the minimum rpm needed to produce the voltage needed to keep the battery charged, turn it to slow and your battery will go dead, or your alternator will over heat and die a sad death.
a higher output alternator will have larger winding, and should be over all heavier duty, so it will be a little extra spinning mass, but it shouldn't ever be over worked, I don't think it will be any easier to spin, but it might last longer.
WTFM8 04-04-2008 06:47 PM
In my experience only a well-designed header will actually do much for modern engines, and even that will make very little difference. On older equipment--predating FI and ECUs--some of that stuff might make be beneficial to FE when coupled with good driving technique; however, I can only speculate on that.
A scangauge is the best bolt-, um, velcro-on accessory for the money, and probably the only one that will surely pay for itself over time.
ankit 04-04-2008 07:14 PM
I saw a thread on another forum where the guy gained ~4 mpg and ~70 mpt after installing a Nismo (made by Nissan) exhaust system. For him it would pay for itself in a little over 1 and a half years. Maybe someone on your tundra forum has experience with a free flowing cat back system that increased MPG for them.
meemooer 04-04-2008 08:12 PM
an E-fan got me 2 MPG on my 4.0 v6. Well worth the money. Felt like i had more power, and after i got used to that the fuel economy went up. Quite easy to install most kits. Plus it is so much safer if ever tooling under the hood with the engine on. You are less likely to stick your fingers into and aftermarket fan as the enclosures have smaller spaces, unlike most factory ones that i've seen are more open
H4MM3R 04-04-2008 09:27 PM
electric fan
WTFM8 04-04-2008 09:44 PM
Is it just large pickups and SUVs that come with belt-driven fans anymore? I'm wondering why this design hasn't been phased out, since the electric just makes more sense. I suppose this can be likened to air-cooled vs. water-cooled motorcycle designs.
In the case your car came with an engine-propelled fan, I do think the electrical replace would help.
LostCause 04-04-2008 11:50 PM
I can't imagine mechanical fans working on anything but longitudinally mounted engines, which are really only common to trucks, SUV's, sports cars, and classic cars. They are probably still being used because they are cheap, and with a fluid clutch can still be effective/efficient.
Headers:
Any aftermarket exhaust is going to be interested in high-hp, which is not useful for hypermiling. Headers that are "tuned" to shift the torque band into lower rpm's would be useful, but they would probably have to be custom made and mated to higher gearing to be useful.
Freeflow Exhaust:
I don't see much of a benefit as under hypermiling conditions the exhaust shouldn't be much of a constriction.
Electrical --> Mechanical Fan:
Beneficial, especially if the fan is not clutched (unlikely). I've seen people switch from clutched fans to electric fans and record a mpg/hp improvement, but I bet the improvement is less than moving from an unclutched fan.
Aluminum Flywheel:
I'd like to know. :) I'd assume lowering reciprocating mass would lower friction/energy consumed, but it kills the idle and makes it easier to stall. Some first had testing would be nice...
Underdrive Pulley:
I would expect a marginal improvement in mileage, but I have no idea of the impact on the cooling or oil pump. An underpullied alternator will probably make up the speed difference by increasing field current (i.e. no MPG gain). Removing items from the circuit (alternator delete, electric coolant pump, etc.) will see bigger gains.
High-Output Alternator:
Not too sure on this. I don't know whether a larger alternator could charge a battery faster than one smaller...which is the only area I could see a decrease in engine load.
- LostCause
diesel_john 04-05-2008 01:08 AM
electric fan only
http://farmindustrynews.com/tractors...-new-products/
trebuchet03 04-05-2008 01:22 AM
Originally Posted by LostCause (Post 17918)
Aluminum Flywheel:
- LostCause
Car Flywheels don't reciprocate ;)
And I agree about the alternator issue... The rating for an alternator is max output - not nominal. Being able to charge faster isn't necessary a good thing - and even then, it's more load over for a shorter duration...
Chris D. 04-05-2008 03:05 AM
Originally Posted by diesel_john (Post 17935)
what does this john deere link have to do with what this post is about?
typo?
Thats what I have, a front engined rear wheel drive truck..
they use em on just about every rwd truck out there..
Headers:
so a direct fitment mite not be the way to roll then?
Freeflow Exhaust:
I can see it from that point of view, but what about in reguards to FE and low end torque?
I'm not sure if its clutched or not..
but I'll find out.. :thumbup:
Aluminum Flywheel:
reciprocating? maybe rotational.. thats a new one to me..
google a "reciprocating saw" and compaire that to what a flywheel does.. ;)
In terms of street/driveability, takes a little bit to get used to it ,
but it was very daily drivable.. made a great deal of difference in acceleration and hp difference in a race vehicle i had, not sure about FE goals tho
Underdrive Pulley:
alternator delete? :confused: how far would ya get till you kill the battery then the ecu looses proper voltage and your DOA.. I donno about that.
Its something I want to do for stereo equipment and having an onboard compressor setup.. :thumbup:
- LostCause
Chris D.
Ryland 04-05-2008 08:47 AM
They have the mechanical driven fan because it's more efficient if the fan is running most of the time, like in a truck! trucks are designed to be under load, as I said before, it's less efficient to convert mechanical to electrical and back to mechanical if it's going to be running 80% of the time that the vehicle is running, my cars fan rarely comes on, the fan on the truck at work is almost always on, why? because it's a truck, and is normally hauling a 5,000+ pound trailer.
If you are using the truck as a sales vehicle, or to tote the kids around, then yes, go with an electric fan, if you use it for it's intended perpus, then stick with the direct drive fan.
Daox 04-05-2008 09:53 AM
I'd definitly agree with Ryland, and most of what LostCause said.
A header properly designed for economy (which eliminates 99% of the headers out there) will give you more more low rpm torque instead of high rpm torque. If you are driving for fuel economy you will never use high rpms so that extra high rpm torque is completely wasted. As mentioned, you'd have to have one custom designed and fabricated. Last I checked this costs upwards of $1000+.
A free flowing exhaust does exactly the same thing, more high rpm torque which you will never use if driving for fuel economy.
I agree with Rylands comments on the E-fan and aluminum flywheel.
Underdrive pulleys can provide benefits, but you have to live with reduced output from your water pump and alternator then. That means you'll lower your towing capacity due to not being able to disperse enough heat, and you won't be able to use that nice big ol sterio that you want.
Personally, the only one I'd even look into on your list is an electric fan.
WTFM8 04-05-2008 02:24 PM
You know, I've only ever open my truck's hood during oil changes. I really should take a look at that design. I suppose the fan design goes along with most of the other engineering in the truck, which seems to be absolute overkill for commuting, but comes in handy when you're pull a trailer with a loaded bed, which is what these vehicles were meant for.
LostCause 04-05-2008 05:13 PM
Good point...:p
Originally Posted by Chris D.
alternator delete? how far would ya get till you kill the battery then the ecu looses proper voltage and your DOA.. I donno about that.
MetroMPG did an alternator delete awhile ago and saw a 10% mileage increase. He used a deep cycle battery and topped it up at home with a trickle charger, I believe. As a safety measure, he kept a custom serpentine belt in the car so the alternator could be reattached if needed.
You run the risk of destroying batteries if you deeply discharge them (depends on commute length), but the potential savings are large.
Its something I want to do for stereo equipment and having an onboard compressor setup...
This will probably work against you since subs, amps, and heavy gauge wiring are all pretty heavy. A large alternator will encourage you to add more extravagence (weight) to your car. :) The compressor might be useful if it allows your to vary your ride height, but your car is already lowered.
- LostCause
Chris D. 04-05-2008 07:05 PM
I'd kill it with my stereo.. ;)
what good is a vehicle without some somfort features..
if I wanted a super ultra mega commuter I'd gut out a festiva so it only had a steering wheel and pedels..
My vehicle makes me money, thats about the only difference
between mine and the majority of other people on here..
WTFM8 04-05-2008 09:28 PM
Oh really? I work as a courier part-time, so my car pays for itself and then some.
Plus, I'd say that anyone who drives to work in a car has a vehicle that "makes them money."
LostCause 04-05-2008 09:32 PM
I drive to school in my car, so does that mean my vehicle helps me lose money x 2? :)
- LostCause
Chris D. 04-05-2008 11:41 PM
:D you know what I mean.. :thumbup::rolleyes:
trebuchet03 04-06-2008 12:30 AM
what good is a vehicle without some comfort features..
Quite good :thumbup:
+exp :D
Knowledge is power they say.... but knowledge comes at a price.... So money>= knowledge is power... money>=power?
For me.. Tuition > cost of food :eek:
Chris D. 04-06-2008 01:01 AM
think of the school thing as an investment..
you'll use gas money to get there, but in all your brain
equity will increase your value and you'll come out on top.. ;)
