Bonneville 8/10/2012
I'll be there, but some question on the trike going.
Anyone else going to be there? Send me a message, and I'll give you my phone number. And either the trike will be there, or the 4 door subaru with roll cage and top chopped off. |
How did it go? Trike make it?
i was there, trike was there, no one else from ecomodder came up and said hi.
we drove it around as spectators some. a LOT of pictures got taken of it. a few comments, all neutral to positive. talked to tech. We cannot run it even if we wanted. it is not a car because it only has 3 wheels and not 4 or more. it is not a motorcycle because two of the tires are not in line. could put "duallies" on the back and run it as a car, and build cage to match, but probably won't. |
So I guess Can Am's couldn't run either? I wonder if this might be a good time to get them to start looking into a new class, especially if more three wheelers are going to start popping up? What about Blue Flame ? It was a tripod.
Glad you got her running:thumbup:. How's she ride? |
stiff. aftermarket springs are about 4 times too high of spring rate.
and fuel injection is a bunch rich - no MAP sensor nor 02 sensor and the computer is a bit confused. and some electrical to sort out. but all in all, it ran. |
