Boston Craigslist d15z1 $250
This isn't my posting, I found this on searchtempest last night and thought I'd share.
92-95 Civic VX motor tran d15z1 engine hypermiler Honda 92-95 Civic VX motor tran d15z1 engine hypermiler Honda - $250 (Lincoln) "92 Civic VX motor and transmission (stock photos, not actual motor) fits '92-95. Not sure of the mileage on this motor, but it had a new timing belt and water pump 10k before it was pulled. Motor comes with d15b7 lx intake manifold with injectors. Also a d16y8 throttle body and exhaust manifold, also has a red d16y8 valve cover and red msd plug wires, original VX manifold is included. The motor does not come with A/C parts or wiring harness, shift linkage is included. This motor came out of a running car, so it should start right up if installed properly, but it has been sitting for a couple of years." |
