EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Brake Specific Fuel Consumption: A Really Useful Concept (https://ecomodder.com/forum/showthread.php/brake-specific-fuel-consumption-really-useful-concept-1800.html)
tasdrouille 04-10-2008 10:48 AM
http://us1.webpublications.com.au/st...ics/110216.jpg
There's a very interesting article on BSFC over at Autospeed. It's a must read for anyone concerned about FE.
http://www.autospeed.com/cms/A_110216/article.html
Daox 04-10-2008 01:45 PM
Very good article. It cleared up a few things I had thought (and was wrong about).
RH77 04-10-2008 10:32 PM
Great find!
It seemed to explain quite a lot that remained unclear...
RH77
PaleMelanesian 04-11-2008 10:52 AM
I have. Pulse & Glide is the best way to take advantage of BSFC.
tasdrouille 04-11-2008 12:50 PM
CVT transmissions are based on this concept.
Daox 04-11-2008 01:26 PM
I just wish that manufactuers published this info! Its almost impossible to find BSFC charts for cars.
PaleMelanesian 04-11-2008 03:37 PM
I've been tempted to go out and make my own bsfc chart. Using the scangauge, do multiple runs on a flat level road. Start at 1000 rpm so and run up through the rpm range. One run at 5% throttle, one at 10%, etc... Rig up a video camera for review and chart out the Gallons / hour vs rpm.
or something like that...
PaleMelanesian 04-11-2008 05:07 PM
I used it to determine the optimum rpm and load for the pulse. I don't have a chart for my engine, but looking at several others, it seems that 1500-2000 rpm and about 3/4 throttle is the peak. That's what I use for the pulse part of my P&G. This way, when you do use the engine, it's at its best (lowest?) bsfc. And when you're not doing that, it's off.
It works, too. Grille block, tire pressure, scangauge, and P&G give me the numbers I have.
MetroMPG 04-11-2008 10:04 PM
I've changed my P&G technique since finding the BSFC map for my engine.
The little 3-cyl mill's peak efficiency is at a higher RPM than I'd been going to previously. It's basically centered just above 3k RPM, where I was aiming for low 2k range before. Makes for brisker acceleration.
