Originally Posted by Winfield1990
..so I think I am going to go with the carb stock motor rebuild , converted from efi because of the wiring problems I just ripped it all out since I couldnt find the problem .
Oh, well when you mentioned carb, I was going to suggest putting in an EFI
From my perspective EFI is easier to troubleshoot, pull the injectors, see if they are squirting the right amount at the right time, scope the cam/crank signals, measure map signals, tps signals, etc. If all the inputs look right and the output is off, then it is the ECU. What goes on in a carb is a bit of a mystery.
