Old 06-03-2014, 03:49 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Machining a crank pulley
I want to get my three belt crank pulley machined to handle just the single alternator belt. Obviously preserving balance in the pulley is critical in the machining process. Any advice about good questions to ask the machinist that has agreed to consider the job?
Believe me I have searched online, and made five calls, and despite the huge aftermarket for Civics there are now no simple bolt-on options for a single belt crank pulley conversion on a sixth Gen (non-VTEC) SOHC Civic 1.6L engine. Unorthodox Racing is out of this game. Ralco makes them for the 1992-1995 but one guy on Honda Tech says he does not think it'll fit a 1998 D16 because, he says, he couldn't swap the stock pulley. Lastly, ATI's pulleys are for serious racing and too expensive.
I know the benefit is small, maybe enough rotational mass reduced to "save" a couple horsepower at the most. But I do a lot of P&G and I have to do the timing belt and therefore the pulley has to come off and therefore this is the simplest time to attempt this mod and so... I'm learning.
j
Old 06-03-2014, 04:06 PM   #2 (permalink)
Any local machine shop with a lathe big enough to chuck up your crankshaft pulley should be able to do this. You'll likely never see $ savings from it since machine time isn't cheap though.
I designed an underdrive crankshaft pulley for the 1st gen Aveo engine. Darin and I had a batch made at a local shop. I think the price per was around $100 to have them made, but we ordered 20 at a crack.
The Following User Says Thank You to Daox For This Useful Post:
California98Civic (06-03-2014)
Old 06-03-2014, 05:15 PM   #3 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
I'd go to the junkyard and try to swap the pulley's first (as much as I think this whole idea is a bad idea). The TDC marks are probably different, remarking would fix.
These guys and others can trim yours down to a single belt.
Or these
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following User Says Thank You to Superfuelgero For This Useful Post:
Old 06-03-2014, 06:22 PM   #4 (permalink)
Anyone with a lathe should be able to do it. But I agree, there are no gains to be had.
Old 06-03-2014, 06:46 PM   #5 (permalink)
Cyborg ECU
I don't expect big FE bonuses or that it will pay for itself soon, but if the OEM pulley weighs 9lbs, machining off the PS and AC positions will cut maybe 5 lbs of completely useless rotational mass. Losing that weight has to mean something for my acceleration pulses during P&G.
Old 06-03-2014, 06:57 PM   #6 (permalink)
Perhaps the "additional" mass allows lower rpms to be employed.
Old 06-03-2014, 07:08 PM   #7 (permalink)
Not really. It does allow you to accelerate faster while maintaining lean burn. P&G is shorter cycles, not sure if it helps or hurts since I'm not much of a P&G'r. I also did the lighter flywheel at the same time too.
Old 06-03-2014, 07:10 PM   #8 (permalink)
When I P&G'd I wished for more flywheel so I could get down to even lower revs w/o lugging.
