BSFC from dyno
1 Attachment(s)
I spent a good chunk of money this week dyno tuning my Nat Asp 2.5L Subaru. Most of the funds were spent in part throttle tuning. I wanted to find the best BSFC at part and full throttle to improve my acceleration efficiency on the street. I already posted a graph in BSFC sticky but I don't think that's very helpful. I'm not good with graphs so I will just post the RAW data which the computer recorded in ascii files here. Aside from using an inductive dyno to calculate power at all wheels, the dyno used sensors on the vehicle to calculate other information such as BSFC. These sensors included injector pulse width reported by ECU, AFR at tailpipe, mass air intake and etc. The ASCII data files were huge and I used them to come up with the following information file (also attached):
http://i.snag.gy/k1kfY.jpg I basically sorted data based on throttle position and found set of RPM's with its respective BSFC, vacuum and power for that engine speed and throttle. The best BSFC for each RPM is highlighted in bold as to simulate best method of acceleration for efficiency. The information gathered from this dyno indicate that at higher engine speeds (+2.3k RPM) wide open throttle is required to achieve best BSFC despite fuel enrichment (λ0.92). Absolute best BSFC was observed at 1800 RPM with 3-4"Hg of vacuum. Vacuum at higher RPMs tremendously degrades BSFC. Leaner mixtures and advanced ignition timing does not make up for vacuum pumping losses but it does improve BSFC. In other words vacuum plays a bigger role than fuel mixture, timing and engine speed to a certain extent for BSFC. If these dyno numbers are to be trusted, high vacuum and engine speeds do not go hand in hand for best BSFC (nothing new here). This further supports longer gear ratios for lower RPM operations at highway speed. Eliminate or minimize vacuum and you are certainly operating at best BSFC so long as fuel mixture is not too rich and timing is not too retarded. Notes:
Sorry I keep asking, any chance you have the original data in log file format?
i.e. just a log of tps/rpm/power/vac/bsfc/anything else? that would be much easier to process in a script to sort it into a bfc-style chart. |
Interesting stuff
I noticed on the new Mazda2 (just launched) it has an electronic throttle body, it fairly obviously changes the throttle position at various RPM's when under full load at low rpm. I guess to maximise BFSC. So a mappable throttle body might be an easy way of achieving the ideal eco results. |
lotsa ways.
if you zip them up, and they are under 100k then you can attach 'em. if under 1meg you can cheat and rename it to .xls and attach it (and make sure we know the original extension). if they are seperate files, the upload limit is only per file, so maybe zipping them up individually or pretending they are .xls files will do (or both). But yah, all the data you got would make the clearest picture. |
Cool Deal!!!:thumbup:
